AFR Fluctuation / at idle? (wideband readings)
Old Sep 6, 2004 | 03:18 PM
slow_dx's Avatar
Default AFR Fluctuation / at idle? (wideband readings)
Setup: 99 b20z, internally stock. JDM DC 4-1, AEM short intake, 2.5" exhaust, chipped p28 running stock LS code with the fuel maps adjusted upwards to compensate for the increase in displacement.
Have been tracking the air / fuel ratio with a wideband sensor to see if fuel or a lack of it is causing a hesitation problem that I am having.
At idle, or during steady state cruising, the air fuel ratio rapidly fluctuates between 14.2 - 15.6
For those of you who run a wideband daily, how much change do you have in the numbers? How lean does your car get, and how rich?
With the throttle closed, I've in the neighbourhood of 17-18:1...
hillbillycivic
29
Nov 10, 2012 04:40 AM
Hockey27925
23
Aug 21, 2005 06:20 AM
clsmooth
Feb 14, 2004 02:12 PM
B_1_8_hatch
Apr 28, 2003 05:21 PM
twin pp
Dec 4, 2002 05:32 AM
