Comptech icebox problem
Old Sep 6, 2004 | 01:56 PM
JDM_Type-R's Avatar
Default Comptech icebox problem
I was driving the R kinda hard the other day, and i hear this thump..and when i get home i see that the tube where the air first enters..its like a curved tube that comes with the icebox is no longer there. its most likely because i currently dont have a fender liner on the passenger side. well anyway, i was wondering if any of you knew if i could get a replacement for just that part alone? any info appreciated. thanks so much.
Old Sep 6, 2004 | 02:03 PM
1GreyTeg's Avatar
Default Re: Comptech icebox problem (JDM_Type-R)
Yes that's been known to happen, mine has also worked it's way loose and off in the past. I check it every time I do an oil change or am under the car or even when I swap tires.
The only place I'd presume you could get just that piece replaced would be Comptech themselves: http://www.comptechusa.com/
The solution to keeping it if it works it's way loose again is to reinstall your fender liner.
Old Sep 6, 2004 | 02:12 PM
JDM_Type-R's Avatar
Default Re: Comptech icebox problem (1GreyTeg)
thanks 1greyteg!!
Old Sep 6, 2004 | 04:00 PM
Tweakmeister's Avatar
you mean the velocity stack?
Mine has fallen off quite a bit too. You really have to get the hose clamp on there tightly. I suppose duct tape wouldn't hurt either.
Old Sep 6, 2004 | 05:46 PM
JDM_Type-R's Avatar
Default Re: Comptech icebox problem (Tweakmeister)
yea i plan on taping it this time and putting my fender liner back on...that way it should be guaranteed to stay on
Old Sep 6, 2004 | 06:55 PM
good stuff, my fender liner caught mine
Old Sep 6, 2004 | 07:55 PM
Bbasso's Avatar
Safety wire it, or use some sort of nut and bolt setup.
Old Sep 6, 2004 | 08:53 PM
JDM_Type-R's Avatar
Default Re: (Bbasso)
ive emailed them..does anyone actually know if you can order select parts of the package?
Old Sep 6, 2004 | 10:01 PM
B2FiNiTY's Avatar
Default Re: (JDM_Type-R)
Just call them tommorow, quick and fast.
Old Sep 6, 2004 | 10:15 PM
nightrider's Avatar
an acura dealership in bellvue i believe is a comptech dealer.
Old Sep 7, 2004 | 02:31 AM
JDM_Type-R's Avatar
Default Re: (nightrider)
yea they are..ill check em out tomorrow..if that doesnt work i guess i call
thanks my asian thug homies!!
Old Sep 9, 2004 | 06:58 AM
iperez's Avatar
Dude !! Call Comptech !! They helped me out in the past and have great customer service..
Old Sep 9, 2004 | 11:20 AM
PlastikOwl
Guest
Posts: n/a
Default Re: (iperez)
*makes a mental note to double check his later*
Old Sep 12, 2004 | 12:57 AM
JDM_Type-R's Avatar
Default Re: (PlastikOwl)
UPDATE
so i called comptech up...$25 shipped for that damn thing..ordered wed, got it SAT
to comptech
this time ima duct tape that focker up, install fender liner, and if it comes off again
ima fockerdoodle someone..whoever happens to be in passenger seat of car
IM ANGRY!!
Old Sep 12, 2004 | 02:00 AM
TheGSRGuy's Avatar
The small metal bracket included with the Icebox...did you install it correctly? Mine was backwards the first time so the velocity stack always wiggled off. I flipped it and the piece never popped loose again.
Old Sep 12, 2004 | 03:20 AM
JDM_Type-R's Avatar
Default Re: (TheGSRGuy)
yes im 100% sure that metal bracket was the right way
bobmugen
Northern California (Sales)
69
May 31, 2009 10:14 AM
yellowbuffalo
Dec 29, 2002 11:56 AM
BSQ
Apr 15, 2002 09:11 PM
94GSRNewbie
Jul 10, 2001 07:33 AM
