Comptech icebox problem
I was driving the R kinda hard the other day, and i hear this thump..and when i get home i see that the tube where the air first enters..its like a curved tube that comes with the icebox is no longer there. its most likely because i currently dont have a fender liner on the passenger side. well anyway, i was wondering if any of you knew if i could get a replacement for just that part alone? any info appreciated. thanks so much.
Yes that's been known to happen, mine has also worked it's way loose and off in the past. I check it every time I do an oil change or am under the car or even when I swap tires.
The only place I'd presume you could get just that piece replaced would be Comptech themselves: http://www.comptechusa.com/
The solution to keeping it if it works it's way loose again is to reinstall your fender liner.
you mean the velocity stack?
Mine has fallen off quite a bit too. You really have to get the hose clamp on there tightly. I suppose duct tape wouldn't hurt either.
UPDATE
so i called comptech up...$25 shipped for that damn thing..ordered wed, got it SAT
to comptech
this time ima duct tape that focker up, install fender liner, and if it comes off again
ima fockerdoodle someone..whoever happens to be in passenger seat of car
IM ANGRY!!
to comptechthis time ima duct tape that focker up, install fender liner, and if it comes off again
IM ANGRY!!
The small metal bracket included with the Icebox...did you install it correctly? Mine was backwards the first time so the velocity stack always wiggled off. I flipped it and the piece never popped loose again.
bobmugen
Northern California (Sales)
69
May 31, 2009 10:14 AM
BSQ
Apr 15, 2002 09:11 PM
94GSRNewbie
Jul 10, 2001 07:33 AM
