The Lysol Trick
Old Sep 6, 2004 | 01:51 PM
Miguel's Avatar
Default The Lysol Trick
Ok, Im attempting to rid my car of that funky smell that came when I recharged my A/C system in my 94 Si Coupe.
After some searching here I learned that the cause of the smell was a bacteria buildup and that there is a Lysol trick to kill the bacteria.
For the mildew smell coming from your vents, try spraying Lysol or some other disinfectant spray into your fresh air intake (should be below your windshield somewhere) while your fan is running with the A/C off... you can also try turning the heater on full blast and letting that run for a while - the mildew comes from moisture buildup from using your A/C. A good tip is to "air out" your vents by turning off the A/C a few minutes before you stop the car. I normally turn off my A/C and recirculate buttons when I get off the freeway.
I understand that you have to spray Lysol into an inlet while the car is running right?
my question is WHERE below the windshield is this inlet? Is it on the top of the dash?
Old Sep 6, 2004 | 01:58 PM
Ricey McRicerton's Avatar
Default Re: The Lysol Trick (Miguel)
Never heard of this, but you can always put it in where your blower motor goes to get it into the vents. Id be cautious about spraying lysol around anythign that shot air at my face though.
Old Sep 6, 2004 | 01:59 PM
Miguel's Avatar
Default Re: The Lysol Trick (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">you can always put it in where your blower motor goes to get it into the vents.</TD></TR></TABLE>
Where is that? Sorry, my knowledge of Hondas is nil... I have always driven German
Old Sep 6, 2004 | 02:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Miguel &raquo;</TD></TR><TR><TD CLASS="quote">
Where is that? Sorry, my knowledge of Hondas is nil... I have always driven German </TD></TR></TABLE>
You can remove your blower motor under your dash with 3 screws/bolts on your passeneger side under the glovebox. Only catch is you can't blow anything with it out.
Old Sep 6, 2004 | 02:20 PM
07's Avatar
07
We do the same thing at the dealer.......
Open the hood. You see the Black plastic with holes? Just below the wipers, and just above the firewall?, that is where your blower motor sucks air in from outside.
Spray all up in there.
Default Re: The Lysol Trick (Calculator)
There you go.
Old Sep 6, 2004 | 02:36 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
febreeze! it makes girls panties drop to there knees. maybe you should try using that..i think it smells good
Old Sep 6, 2004 | 02:57 PM
yellowmonkeyboy's Avatar
good info
Old Sep 6, 2004 | 03:33 PM
ATS*Mark's Avatar
OG triple OG
Default Re: The Lysol Trick (ciRcuitSi y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitSi y0! &raquo;</TD></TR><TR><TD CLASS="quote">febreeze! it makes girls panties drop to there knees. maybe you should try using that..i think it smells good</TD></TR></TABLE>
does it fo real???? cause my car already vibrates and gets the girls going , if i spray that **** in there the car will be a high performance sexual machine
Old Sep 6, 2004 | 03:36 PM
Miguel's Avatar
Default Re: The Lysol Trick (Hella_JDM)
If only girls where attracted to rust...
Old Sep 6, 2004 | 03:39 PM
Ya@inlinePRO's Avatar
i read about the filter trick on s2ki.com
everyone says its the most effecient.
Old Sep 6, 2004 | 09:25 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (kwik2nec)
what filter idea
Old Sep 6, 2004 | 09:30 PM
SiYouLater's Avatar
but febreeze doesnt kill bacteria.
Old Sep 6, 2004 | 09:32 PM
BatuKing's Avatar
No Febreeze doesnt kill the bacteria / mildew on the evaporator as lysol does.. You need something that kills it both,
As far as putting it in. you have a recycle blend door behind your glove box. take the lysol can and spray it in there, Now when you do spray do alittle bit at a time and get ready for the car to stink up like lysol, I open all the doors and let it sit for a few hours
motegicivic
11
Dec 12, 2011 03:41 PM
Black Diamond
Apr 4, 2009 07:16 PM
Mixturepinoy
May 12, 2004 09:02 AM
JunIntegra
Apr 13, 2004 05:13 PM
type Gendy
21
Oct 6, 2003 02:31 PM
