Cap and rotor killed the Civic?
Old Sep 6, 2004 | 11:37 AM
kstafford's Avatar
Default Cap and rotor killed the Civic?
I just put a new distributor cap and rotor on a 1992 Civic, after which it ran perfectly for about five minutes, then stopped firing entirely. Anyone seen any bizarro stuff like this before? I can't find anything fried, but it just won't fire! Losing my mind. Any suggestions appreciated.
Thanks.
Kevin
Old Sep 6, 2004 | 11:51 AM
hatchi's Avatar
Default Re: Cap and rotor killed the Civic? (kstafford)
is it cranking?? any CEL's?? igniter might have gone bad
Old Sep 6, 2004 | 11:58 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Cap and rotor killed the Civic? (hatchi)
you forget to put the rotor screw back on
Old Sep 6, 2004 | 12:08 PM
kstafford's Avatar
It turns over like a big dog, just won't fire a lick. I thought maybe the spring fell off of the coil or something, but it's there. I'm starting to think the danged igniter did go bad, but what are the odd of that happening right after replacing the cap and rotor? It just weirds me out... Every boneyard in the world is closed today too...
Old Sep 6, 2004 | 12:09 PM
Evs-One's Avatar
Solbros Owns Me
have you removed the cap and inspected yet?
Old Sep 6, 2004 | 12:14 PM
murtnabila's Avatar
Default Re: Cap and rotor killed the Civic? (Emerika)
open it up and see if you done it right? And give more detail of what it does and does not do. Any wierd noises? ect...
Old Sep 6, 2004 | 01:04 PM
kstafford's Avatar
It had to have been right - it ran great for about five minutes. I've had the cap and rotor off about 15 times since then, and don't see anything broken, loose, dorked up, etc... right now I'm trying to find the diagnostic plug to see if I can get it to puke out any codes... No weird noises, just no fire... Cap and rotor look fine. I even put the old ones back on and tried that, no dice. Didn't forget the rotor screw or anything goofy like that ;-)
Old Sep 6, 2004 | 02:03 PM
murtnabila's Avatar
check and see if all 4 plugs are getting spark
legendre
Nov 7, 2013 03:00 AM
xstalkrx
May 21, 2007 04:34 PM
bizmackus
Feb 25, 2007 09:33 PM
Unjockable
20
Feb 15, 2004 03:49 PM
MysteriousGSR
Apr 28, 2002 08:12 PM
