buying b16, have a few questions
Old Sep 6, 2004 | 11:27 AM
BeerBaron105's Avatar
Default buying b16, have a few questions
im buying a b16a2 off a 2000 SIR, i have a 1999 civic dx, is the swap basically a plug and play since my car is essentially the same as an Si(R), i know i have to wire for vtec, but can i use my stock harness, swap ecus and be done with it or are there different pinouts, and the engine comes with all mounts attached, i heard u need the rear tranny mount off an Si(R), so will that plug together, it also comes with the axles
is there anytihng else i need to make this swap happen, anything i should prepare for, thanks
Old Sep 6, 2004 | 01:46 PM
ttt
Old Sep 6, 2004 | 02:21 PM
stripes777's Avatar
u wont get help with that question here, with that many posts, u should already know that
Old Sep 6, 2004 | 02:39 PM
carlton585's Avatar
when i did mine into my eg, i used the d series rear mount, and it came with the other two that i needed. ran vtec to the shock tower, and the knock sensor through the hole in the firewall. other than that, ur good (assuming its the same)
jpullen
Jun 28, 2013 09:43 AM
pulpjuice
Jan 18, 2012 08:02 AM
ablack934doorcivic
Jul 9, 2004 12:32 PM
sikcrx80
Jul 14, 2003 07:10 PM
the DR.
Nov 3, 2002 07:11 PM
