No vacuum to the map sensor
Old Sep 6, 2004 | 10:53 AM
Ri5e's Avatar
Default No vacuum to the map sensor
My friend has a 89 CRX with a B17 motor, we connected a vacuum gauge to the vacuum hose that connects to the map sensor and it's reading 0 psi at idle. Is this normal??
We then connected the gauge to the FPR vacuum source and it's reading fine (has vacuum during idle).
Old Sep 6, 2004 | 11:12 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: No vacuum to the map sensor (BG Boost)
yes, that is perfectly normal. Your MAP runs off of vacuum which is normally measured in inches of mercury not pounds per square inch.
Now, I belive you folks connected the MAP hose to that big vaccum tube smack in the center of the throttle body, Right?
That is for the EVAP system and it only sees vacuum when the throttle is opened. No vacuum during idle.
So look to the right of that center tube and you should see another vacuum fitting. That's the one for the MAP sensor.
Hope that's it.
Old Sep 6, 2004 | 12:01 PM
Ri5e's Avatar
Default Re: No vacuum to the map sensor (The new Spaceballs)
So inches of mercury must be a really really small reading that the gauge can't even read it? Because the gauge, which is actaully an electronic Greddy boost gauge, sees 0 PSI constantly.
Old Sep 6, 2004 | 01:27 PM
ScottEK's Avatar
Does the gauge show only positive pressure or does it go past 0 on the negative side and show vacuum?
Old Sep 6, 2004 | 02:07 PM
Ri5e's Avatar
Default Re: No vacuum to the map sensor (beta13)
Vacuum and Positive. It's a turbocharged motor b.t.w....
Also, when disconnecting that vacuum line to the map sensor, the car still idles fine.
Old Sep 6, 2004 | 02:20 PM
Ri5e's Avatar
I circled it in red. It's getting a 0 psi reading in idle:
Old Sep 6, 2004 | 02:24 PM
fourthgenhatchB17's Avatar
Hmm..i dont know if there is vacuum there at idle, i have never really checked that. Spray some carb cleaner in there and see if its clogged ?
edit: i see the problem, u have your coolant reservoir in the wrong spot. j/p
Old Sep 6, 2004 | 02:28 PM
johnzm's Avatar
Default Re: No vacuum to the map sensor (fourthgenhatchB17)
seriously, those TB connections are crappy. ive noticed some very low vac readings from the nipples on the TB. so for future reference i would route ALL vac sources from the IM and T offf anything from those.
Old Sep 6, 2004 | 02:29 PM
No Big Whoop
You will not see PSI out of there at idle.
It will always read zero PSI at idle.
You need a "vacuum" gauge.
Take the throttle body off and clean that passage with a needle and some carb cleaner.
That shuld fix the problem
Old Sep 6, 2004 | 03:12 PM
Ri5e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs &raquo;</TD></TR><TR><TD CLASS="quote">You will not see PSI out of there at idle.
That shuld fix the problem</TD></TR></TABLE>
The Greddy gauge that he has is a vacuum/boost gauge.
Old Sep 6, 2004 | 05:11 PM
Ri5e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Hmm..i dont know if there is vacuum there at idle, i have never really checked that. Spray some carb cleaner in there and see if its clogged ?
edit: i see the problem, u have your coolant reservoir in the wrong spot. j/p</TD></TR></TABLE>
What I don't get is ... his car is turbocharged. If it is "clogged", wouldn't the pressure force all that gunk out?
aligntv
Feb 14, 2017 06:16 PM
hillbillycivic
Feb 26, 2015 03:35 PM
roachsboosted16
Apr 1, 2008 07:35 PM
Qveon
Apr 30, 2007 10:35 PM
eightvalver
Aug 23, 2004 08:41 PM
