Effective compression ratio
Old Dec 6, 2001 | 02:05 PM
HX_Guy's Avatar
Default Effective compression ratio
If two motors have the same effective compression ratios, regardless of induction type, should they make the same power?
Old Dec 6, 2001 | 02:21 PM
Jim S. '95 Z28's Avatar
Default Re: Effective compression ratio (HX_Guy)
Do these two motors have any different specs?
Old Dec 6, 2001 | 02:34 PM
HX_Guy's Avatar
Default Re: Effective compression ratio (Jim S. '95 Z28)
Well say one is turbo and the other is all motor.
Examples:
Static compression: 9.6:1
Boost: 6 PSI
Effective compression: 13.5:1
Static compression: 13.5:1
Boost: 0
So the effective compression of the motors is the same, but I would imagine the boosted motor would make more power. Why is that?
Old Dec 6, 2001 | 03:06 PM
Unless the n/a motor operates at 100% volumetric efficiency, effective/dynamic compression will be quite a bit less than static compression. Also, unless running a HUGE cam, 13.5:1 compression on pump gas ain't happening.
Even if both motors sport similar displacement, there are FAR too many variables to consider: cylinder head flow, cam profiles, boost, a/f ratio, timing maps, operating RPM range, etc. Compression ratio alone does not dictate power output.
To answer the original question as simply as possible, the forced induction motor simply moves more air, hence greater power production.
Old Dec 6, 2001 | 03:14 PM
VTEC4GS's Avatar
yeah, many people dont understand the difference with running that high compression with a Type R cam vs. a Toda Spec C cam ...
pretty much the answer is volumetric efficiency and O2 content.
Greg
[Modified by vtec4gs, 4:14 PM 12/6/2001]
Old Dec 6, 2001 | 03:24 PM
Default Re: Effective compression ratio (vtec4gs)
To add, compression ratio, as the name states, is a ratio of cylinder volume at TDC divided by cylinder volume at BDC. Regarding the two motors in question, although they both feature the same compression ratio, there a whole lot more air in the forced induction motor at BDC compared to the n/a motor.
i20ar
Sep 17, 2005 12:48 PM
b18c5turbo
Jul 15, 2005 02:51 PM
TehMoonRulz
May 16, 2005 01:15 PM
josh green
Oct 23, 2004 03:03 PM
