oil coming from the back of car
Old Sep 5, 2004 | 08:31 AM
afhockeyfreak4ml's Avatar
Default oil coming from the back of car
ok well theres some oil coming from the back of my 93 lude H23. and theres alittle bit of it right next to the headers and the engine. what could this be?
Old Sep 5, 2004 | 08:42 AM
five-0's Avatar
Default Re: oil coming from the back of car (afhockeyfreak4ml)
Loose oil filter? Maybe? Probably?
Old Sep 7, 2004 | 07:20 PM
Default Re: oil coming from the back of car (five-0)
they why would it be coming out the headers ??
Old Sep 7, 2004 | 07:30 PM
preludeez's Avatar
is it next to or coming out of the header?
also, a little more info would be great, symptoms/details.
Old Sep 7, 2004 | 10:27 PM
OEM_ASSASSIN's Avatar
Default Re: oil coming from the back of car (preludeez)
Probly talking about it dripping onto the piping. Check your oil filter. If oil is coming out of the front check your valve cover gasket. My F22A had oil all over the front of it cause the gasket was bad.
Old Sep 7, 2004 | 11:31 PM
SKDRCR's Avatar
Default Re: oil coming from the back of car (OEM_ASSASSIN)
so is the oil all over the underside of the car?
can you tell where the source is?
If your car is sitting in neutral, can you see it dripping.
It could be a number of things. Oil cooler gasket/0-ring, rear
main seal, cam seals, etc.
We need more datailed information for a better analysis
Old Sep 8, 2004 | 05:43 PM
Default Re: oil coming from the back of car (SKDRCR)
the oil is coming from the top of the header where it touches the engin like where it is bolted to it. it looks like its coming from a bolt.
Old Sep 8, 2004 | 05:51 PM
SUB-0 H23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">so is the oil all over the underside of the car?
We need more datailed information for a better analysis </TD></TR></TABLE>
im pretty sure that is the problem
Old Sep 8, 2004 | 07:17 PM
chrysler kid's Avatar
sounds like a blown headgaskett or blown head seal if its dripping onto the header. if theres oil coming out of hte back its probably from the oil filter not being sealed to the block correctly
Old Sep 8, 2004 | 07:35 PM
93preludeBB's Avatar
Sounds like: valve cover gasket or head gasket
I think my 93 h23 is about to **** hte bed also.
mrspeedy69
14
Feb 5, 2012 11:48 AM
mwstrick
Jul 24, 2007 09:19 PM
B16CivicEX
May 30, 2006 03:15 PM
lanojp1
Sep 2, 2004 04:00 PM
anirtak
Mar 16, 2004 06:16 PM
