B16A enigne mounts?
Hey guys Im swaping a B16A firsg gen into a 92 civic hb si. Now Ive been doing alot ot research and found some confusing results.
What engine mounts do I have to use?
Can I reuse some of the original mounts?
I read that you can use the original mounts except for the rear mount and the one next to the timming belt.
Any input would be great guys
Thanks
Thanks
you can use the stock timeing belt mount, and the tranny mount but you have to use a back mount from a DOHC delsol, 94-up integra(doesnt matter what model ,LS,GSR, Type R). 99-00 si back mount will not work. you also have to use the eg d mount that is held on by 14mm bolts, under the frame...hope that helps you out
97civicdx
Feb 9, 2005 12:32 PM
