Help with compression (this motor building stuff is crazy!)
Old Sep 4, 2004 | 06:26 PM
done's Avatar
Default Help with compression (this motor building stuff is crazy!)
10.9 84.5mm GSR Arias Flatop pistons + Itr head + supertech "domed" valves (turbo version with inverted dome) = Lower then 10.1 compression??
I know someone must know, any help would be greatly appreicated...
Old Sep 4, 2004 | 06:53 PM
sporkcrx's Avatar
Default Re: Help with compression (Jordo)
Might want to throw in what head gasket you're using.
Old Sep 4, 2004 | 06:57 PM
done's Avatar
Default Re: Help with compression (sporkcrx)
stock head gasket
Old Sep 4, 2004 | 07:14 PM
sirb18a's Avatar
http://www.c-speedracing.com/h...c.php
check it out
Old Sep 4, 2004 | 07:26 PM
DaveF's Avatar
Default Re: Help with compression (sirb18a)
maybe its a little higher than i had thought.. hmmmm
10.547005367477691 (from what i pluged in on the c speed calculator) 84.5mm bore
with an 81mm bore and all the other same value's(9.891124185252893)
Old Sep 4, 2004 | 09:25 PM
B-seriesbuilders's Avatar
buy a stock three-ply head gasket take out the ribbits from the head gasket and separate the three layers ,throw away the center layer and sandwhich an aftermarket headgasket between the two stock layers, and tighten it really well.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">10.9 84.5mm GSR Arias Flatop pistons + Itr head + supertech "domed" valves (turbo version with inverted dome) = Lower then 10.1 compression??
Old Sep 5, 2004 | 02:09 AM
itralex's Avatar
Default Re: Help with compression (B-seriesbuilders)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-seriesbuilders &raquo;</TD></TR><TR><TD CLASS="quote">buy a stock three-ply head gasket take out the ribbits from the head gasket and separate the three layers ,throw away the center layer and sandwhich an aftermarket headgasket between the two stock layers, and tighten it really well.</TD></TR></TABLE>
errr.......That would raise his CR number instead of lowering it
Old Sep 5, 2004 | 07:24 AM
DaveF's Avatar
Default Re: Help with compression (HypeR1004)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HypeR1004 &raquo;</TD></TR><TR><TD CLASS="quote">
errr.......That would raise his CR number instead of lowering it</TD></TR></TABLE>
you have mis read my friend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-seriesbuilders &raquo;</TD></TR><TR><TD CLASS="quote"> sandwhich an aftermarket headgasket between the two stock layers</TD></TR></TABLE>
this is how its done on low budgets.
Old Sep 5, 2004 | 08:17 AM
done's Avatar
Default Re: Help with compression (Dturbocivic)
i pluged it in and came up with 10.03.
then using the specs from arias site. came out with 9.6:1.. how in the hell do they get those pistons to 10.9
Old Sep 5, 2004 | 01:26 PM
itralex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
damn....missed the aftermarket sandwiching part
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
raphael
Feb 16, 2007 10:21 AM
sircrxracer
Apr 7, 2004 04:01 AM
p1ccoloz
Apr 21, 2003 09:41 AM
Charlie Moua
Mar 19, 2003 06:12 AM
