Welding Inconel
Old Sep 4, 2004 | 06:10 PM
spoonhatchblack's Avatar
Default Welding Inconel
Has anyone had any experience with welding inconel? I know it withstands high temperatures, but I'm planning to weld steel with inconnel if at all possible. Any insight from the experienced would be highly appreciated.
Old Sep 5, 2004 | 12:53 AM
Ekasey's Avatar
Default Re: Welding Inconel (spoonhatchblack)
http://www.burnsstainless.com
Look under our tech articles for more info and yes you can weld steel to inconel, but may i ask why? if it's stainelss i can understand but mild steel?
Old Sep 6, 2004 | 06:01 PM
.dave's Avatar
i HAS questions ?
Default Re: Welding Inconel (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.burnsstainless.com
Look under our tech articles for more info and yes you can weld steel to inconel, but may i ask why? if it's stainelss i can understand but mild steel?</TD></TR></TABLE>
Steel exhaust flange to inconel manifold?
Old Sep 6, 2004 | 06:18 PM
Ekasey's Avatar
Default Re: Welding Inconel (dave.g)
It can be done<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dave.g &raquo;</TD></TR><TR><TD CLASS="quote">
Steel exhaust flange to inconel manifold?</TD></TR></TABLE>
Old Sep 6, 2004 | 07:37 PM
.dave's Avatar
i HAS questions ?
I'm just guessing he doesn't have a piece of inconel laying around to machine into an exhaust manifold.
Old Sep 7, 2004 | 04:11 AM
sinister6's Avatar
well, inconel cost is very high as well, i dont know, if SS can do it then why inconel?
Old Sep 7, 2004 | 07:14 AM
Ekasey's Avatar
Default Re: (sinister6)
Inconel is horribly expensive but is a wonderful material.
It yeilds very great high heat strength etc. etc.
Old Sep 7, 2004 | 06:52 PM
tony1's Avatar
Default Re: (eLusive ek4)
We were set on using Inconnel on the headers for Rado's celica...until we found out the price! lol. I did alot of research on it and about welding it. I found that not too many people have welded it before, but those that have say it's kinda like welding dirty stainless. I have yet to get my hands on any, but would like to mess with it a bit.
Old Sep 7, 2004 | 06:53 PM
Ekasey's Avatar
Default Re: (tony1)
We have some scraps laying around the shop, but they are miiiiiiiine all miiiiiiine!!!!!!!!!! muahahahha
ok im done
I talked to bob today tony didnt know anyone from norwood was on here
Old Sep 7, 2004 | 07:01 PM
tony1's Avatar
Yeah, i heard him talking to you today, didn't know you were on here though. Hook me up with some scraps man, I gotta learn somehow, can't afford to learn on $200 U bends!!! lol
Old Sep 8, 2004 | 12:52 PM
Masta's Avatar
Default Re: (tony1)
I've welded it, but I'm not versed on the theory behind it. An older guy instructed me by saying " Don't heat it up too much, it'll crack" With that I proceeded to weld it. It didn't crack. It seemed to weld just like S.S. but I was very careful not to sit on it too long. Hrm.
D.
Old Sep 9, 2004 | 08:49 PM
Brandon Clifton's Avatar
Yes, it can indeed be done. Grab some Hast W weld wire and you can stick about any two alloys (excluding aluminum based) together (mild to stainless, mild to inco, mild to hast, stainless to inco/hast, cast iron).
Tony- I don't know where or how you did your research but I've got 20 guys that weld inco for me at least once per week. Based on the number of aerospace shops in the USA alone, I'd say there are thousands of people welding on inconel at any give time of the day.
As for expense, about the only engineering superalloys more expensive are Haynes 188 and Waspaloy. Both are in the $100/lb range for sheetmetal. Inco is in the $70/lb range.
Check my "welding reference" post for pics. I'll get some inco weld pics up soon, and if you guys want to bounce any questions off me I'll do my best to answer or pass them along to my welders.
Old Sep 10, 2004 | 09:28 AM
Ekasey's Avatar
Default Re: Welding Inconel (Brandon Clifton)
Brandon
There may be 1000's of people welding inco in the aerospace industry everyday but it is not the exact same thing as welding inconel for automotive.
I will have to try some of the Hast W weld wire see how well it performs next time i get a chance. Thanks for the recommendation
Old Sep 10, 2004 | 06:15 PM
tony1's Avatar
I was actually told that by the guy at the the lincoln booth at sema last year. He was working the booth demonstrating the machines. This was in reference to .025" or so inconel tubing for headers. I don't know what kind of heat you'd normally weld inconel with, if it's similar to stainless then low amperage wouldn't be an issue with the thin tubing, but if it wants a lot of heat then it'd be a bit tougher with .025 tubing.
Old Sep 10, 2004 | 08:53 PM
Default Re: Welding Inconel (tony1)
One amp per thousandth of an inch (25 amps for .025, etc)
As for "inconel for automotive," we use it in many different configurations (sheet, foil, bar, forging, etc) and they all weld pretty much the same. Let me talk to our CORE welder and see what he says.
HT Chaplain
Welding / Fabrication
Jan 25, 2008 06:23 PM
TEGNO1
16
Jan 18, 2007 02:18 AM
CBURKE
Oct 30, 2006 07:06 AM
silentdaredevil2
Jul 24, 2006 10:41 AM
J337_UNIT
Mar 20, 2004 07:24 PM
