fog light wiring
Old Sep 4, 2004 | 11:49 AM
lYellowDragonl's Avatar
Default fog light wiring
i was wonderin if i take the wires for the fog light and wire it up to the headlight fuse will the headlight dim out or no? and do they produce enough amps to power both them up? cause i want to have them on with the headlights with out a switch
Old Mar 7, 2005 | 12:27 AM
trooper0641's Avatar
Default Re: fog light wiring (lYellowDragonl)
Old Mar 7, 2005 | 12:37 AM
hahagasdcrx's Avatar
use a relay. That way you dont keep popping fuses or melt a wire.
Old Mar 7, 2005 | 06:54 AM
HiProfile's Avatar
Just make sure you use a relay rated for the fog lights and include an inline fuse for the fog lights. If you have any unused fuse spaces on your fuse block, you can also wire it up to that space.
MattNYC
Sep 12, 2011 03:34 PM
89 ed6 FTW!
23
Jan 16, 2011 09:24 AM
tegdude227
Lighting
17
Jan 20, 2008 06:02 PM
.Slug
Oct 29, 2006 10:04 AM
EJ8 GSR-T
Sep 16, 2004 07:31 PM
