weird overheating problem with 00 si with 00 gsr motor
here's the problem, when i am driving my car will start to overheat, only when it is hot outside in the day time, when it is night time, it will not overheat, when my car is seating with the engine on the fan kicks in normally,
also when my ac is on it starts to overheat too...
when my engine is on and i turn on the ac, are both fams suppose to be on?
what could cause this? bad grounds? relay problems?
thanks
thanks
it sounds like your water pump sucks, have u replaced ur thermostat? id to that first, and see if it contenuies, if it does your water pump is going to chet....your not leaking and coolant right???
Lightsped
Sep 3, 2012 08:34 AM
96Civic_Coupe
Jul 3, 2006 06:14 AM
