got check engine light: 1
Old Sep 4, 2004 | 08:44 AM
PanamaVTI's Avatar
Default got check engine light: 1
according to the codes.. its the oxgen sensor..
Can this be fixed?? cleaned?
I know the oxygen sensor is very expensive... mucho $$$, I'd rather not have to buy one...
Old Sep 4, 2004 | 09:13 AM
LifeOnFire's Avatar
same thing os wrong on my 97. it may be because of my air intake though. not sure exactly. yeah, those are in upwards of about 80 bucks. you could try to take it out and hit it with an air compressor or wipe it down or something. ill try that myself and let you know if it works
Old Sep 4, 2004 | 09:47 AM
PanamaVTI's Avatar
Default Re: (LifeOnFire)
80 bucks?? more like 200 or 300...
the intake??teh o2 sensor is the one on the header.
Old Sep 4, 2004 | 10:12 AM
Andres-eh2's Avatar
try cleaning like he said. they have special sprays for the electronic stuff. Did you swap in that motor? try resetting the ECU?
Old Sep 4, 2004 | 10:17 AM
SprayinCX's Avatar
Default Re: (Andres-eh2)
you can take carb cleaner and spray it to clean it. i have done that before, BUT you must let it dry completely before you put it back in and crank the car. it could possibly damage the o2.
Old Sep 4, 2004 | 10:33 AM
huntarrr's Avatar
Default Re: (PanamaVTI)
yup, if you're talking about the primary o2 sensor (i'm assuming you're obdII) then it's going to be upwards of about $220 at the dealership. you cand find used ones for pretty cheap (if not free). search around in the classifieds and im sure you'll be able to locate one.
carb cleaner might salvage it, but if you can get a working one for $20, i'd just buy a new one.
Old Sep 4, 2004 | 10:37 AM
SprayinCX's Avatar
Default Re: (vsm98civic)
you can buy the "universal ones" at autozone or advance for like $40-$50. but yuo have to cut your old plug and use it on the new one. i have no idea how goof they work though.
omaralbasri1
12
Mar 11, 2012 08:28 PM
etherspeed
Honda Civic (2001 - 2005)
Jun 9, 2008 06:06 AM
dre2day
Feb 27, 2008 07:27 PM
mattsthru
Feb 21, 2007 01:44 AM
djtech
Feb 6, 2003 05:34 PM
