What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN?
Old Dec 6, 2001 | 09:53 AM
Spade's Avatar
Default What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN?
I see these on Oil coolers and Fuel lines as well as braided hoses......what do these connectors look like are they screw on's?
Old Dec 6, 2001 | 05:58 PM
g4b17's Avatar
New User
Default Re: What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN? (Spade)
AN is a standard of measurement. the dash number is the size of the fitting and the number before the dash tells you what the part is, weather it is a union or an elbow ect. Most of the fittings you will find in fuel, oil and hydraulic systems use this system of measurement. yes the are threaded
Old Dec 6, 2001 | 07:07 PM
earl's Avatar
and the AN stands for Army-Navy
Old Dec 7, 2001 | 06:16 AM
Crazydave's Avatar
Default Re: What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN? (earl)
-3 and -4 lines are usually used for oil lines....
they are small
the -8 are quite bigger...
Old Dec 7, 2001 | 06:40 AM
Davep's Avatar
Default Re: What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN? (Crazydave)
The -4, -6 line or whatever is the numerator in a fraction over 16. So a -4 line size is 4/16= .25" in size and the -8 is 8/16= .5" etc.
Old Dec 7, 2001 | 06:41 AM
Spade's Avatar
Thnx guys, going to get silly and over cool the fuids in the car.....oil cooler, tranny cooler, and what do you guys think about a Fuel cooler....? After all it is only 30 bucks.....then I would have to hose it up......is it logical in any way to install a fuel cooler? Future plans for the Chasis is a Non VTEC Turbo....
Building the D16 isn't worth it.
Old Dec 7, 2001 | 11:08 AM
Mista Bone's Avatar
D Tranny Guru
Fuel cooler only needed on old V8's with mechanical fuel pumps.
They tend to vapor lock rather easy.
Old Dec 7, 2001 | 12:34 PM
Spade's Avatar
Default Re: What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN? (Mista Bone)
kewl....thanx
Old Dec 7, 2001 | 08:50 PM
HXMan's Avatar
Default Re: What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN? (Davep)
That helps a whole hell of alot....Now, what about -4 NPT. WTF does NPT mean?
Old Dec 7, 2001 | 09:32 PM
earl's Avatar
Default Re: What the heck are AN connectors? Example -6 AN, -4 AN, and -8 AN? (HXMan)
National pipe thread. Comes in 1/8 inch, 1/4 inch, 3/8 inch etc. etc.It's a tapered fit thread. No o-rings or bevels necessary.
Old Dec 8, 2001 | 12:48 AM
B18C-EJ1
Guest
Posts: n/a
Wow! I always thought the AN stood for American National (pipe thread that is).
Learn something new every day.
matttegra
Sep 7, 2010 04:58 PM
90DALS
May 17, 2010 05:46 AM
GotRiceYo
May 16, 2008 01:03 PM
Snail Tuning
Feb 1, 2003 08:44 PM
pelotudo
Aug 24, 2002 12:20 AM
