ok... jdm itr pistons vs usdm itr pistons??? what you think is be better for a b18c1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gulftiresinc »</TD></TR><TR><TD CLASS="quote">ok... jdm itr pistons vs usdm itr pistons??? what you think is be better for a b18c1?</TD></TR></TABLE>
they both trash...get b16 and stuff it in ur gsr and the compression will jump up because of b16 top head design and cheaper price....? you don tknow that?
Munkyw3rkz.webs.com
depends on what you want out of it...
JDM ITR's yeild a higher compression
USDM is lower
USDM is lower
or cause he just wants to say that hes got some jdm slugs in his motor
From: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake EG »</TD></TR><TR><TD CLASS="quote">depends on what you want out of it...
USDM is lower</TD></TR></TABLE>
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9krpm »</TD></TR><TR><TD CLASS="quote">or cause he just wants to say that hes got some jdm slugs in his motor </TD></TR></TABLE>
tru....as for me i can care less ill say i have a B16 with with JDM H22 pistons!
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr »</TD></TR><TR><TD CLASS="quote">
they both trash...get b16 and stuff it in ur gsr and the compression will jump up because of b16 top head design and cheaper price....? you don tknow that?</TD></TR></TABLE>
you are correct with the PR3 piston he will have a higher comp, however the PR3's do not have the protective coating that the ITR slugs do!
i was told that the JDM itr pistons in a b18c1 would be best for all motor with NOS is that true?
Munkyw3rkz.webs.com
any motor with NOS would be good! it all comes down to how much NOS tuning ETC!
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR »</TD></TR><TR><TD CLASS="quote">what CAMS do you plan on running? </TD></TR></TABLE>
tru cams play a issue with comp as well
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrhumphrey »</TD></TR><TR><TD CLASS="quote">jdm pistons
higher compression ratio.......if you are gonna spend the time to change out the pistons you might as well go for broke, know what i mean.
</TD></TR></TABLE>higher compression ratio.......if you are gonna spend the time to change out the pistons you might as well go for broke, know what i mean.
dc2_dude
Mar 27, 2007 09:59 AM
