Confused with tie bars and sway bars???
Old Sep 3, 2004 | 10:31 PM
OneFire's Avatar
Default Confused with tie bars and sway bars???
I drive a 98 civic hatchback and I was wondering if the oem jdm itr front and rear tie bars fit on a hatchback ( what I mean is plug and play)
Also does the itr front lower and rear sway bars fit my hatchback?
thanks
Old Sep 3, 2004 | 10:39 PM
ek4d00r's Avatar
Default Re: Confused with tie bars and sway bars??? (Eg_Egg)
the ITR front would require you to get at least the A arms (theres more but i cant remember) off the EM1 (99-00 civic si). the 96-00 civic ex front sway is easier since you dont really need to swap anything out for it. the ITR rear sway would require EM1 endlinks but thats about it. be sure to get a reinforcement kit such as the ASR or beaks so you can at least try to avoid tearing the subframe
Old Sep 3, 2004 | 11:03 PM
Street Ghost's Avatar
Default Re: Confused with tie bars and sway bars??? (slowEKsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowEKsedan &raquo;</TD></TR><TR><TD CLASS="quote">the ITR front would require you to get at least the A arms (theres more but i cant remember) off the EM1 (99-00 civic si). the 96-00 civic ex front sway is easier since you dont really need to swap anything out for it. the ITR rear sway would require EM1 endlinks but thats about it. be sure to get a reinforcement kit such as the ASR or beaks so you can at least try to avoid tearing the subframe</TD></TR></TABLE>
I think he has an EG based on his user name.
What car do you have anyways?
Old Sep 3, 2004 | 11:06 PM
ej0513's Avatar
well.. he mentioned that he has a 98 Hatchback.. so.. EK maybe?! well.. you can get a CTR/Si front sway bar (26mm) but you will need the shock forks, LCAs, and the d-links.. and all the stuff to connect the bar to the chassis and LCAs. perfect fit.. as far as the rear goes, the ITR will fit but i think you would be better off going with a Comptech or Suspension Techniques for the bracing that they offer.
EFRue57
Suspension & Brakes
Oct 16, 2009 06:20 AM
EFRue57
Oct 15, 2009 05:15 PM
SD_EM1
Jul 21, 2003 08:51 PM
JOHN WAYNE
Oct 10, 2002 12:05 PM
tFUnK
18
Feb 8, 2002 11:24 AM
