What happens when...
Old Sep 3, 2004 | 05:16 PM
Jeef's Avatar
Default What happens when...
well when i bought my car it had a mini me swap done to on it... well i recently spun a rod bearing, and after pulling the head off i noticed that whoever did the swap never pulled the oil jet out of the block, i know you are supposed to remove it, but what effect is there when you don't?
Old Sep 3, 2004 | 05:26 PM
LAMA's Avatar
Default Re: What happens when... (Jeef)
i heard that if you dont take it out it does nothing. you wont be able to tell. but you wont have vtec
Old Sep 3, 2004 | 05:29 PM
LAMA's Avatar
Default Re: What happens when... (LAMA)
"I forgot to pull the oil jet out the first time. You won’t get a code, your ECU will say your solenoid is fine and everything is working great but VTEC will not actually engage."
quoted from EF-honda mini me how to article found here
Jeef's Avatar
nope thats not the case, i def. had vtec...
Old Sep 3, 2004 | 05:34 PM
LAMA's Avatar
*weird*
Old Sep 3, 2004 | 05:35 PM
Jeef's Avatar
maybe thats if you are running with the p28??? i'm running the ghetto way with the pm6 and msd switch..
Old Sep 3, 2004 | 07:14 PM
fourthgenhatchB17's Avatar
THe MSD switch may have something to do with it. The P28 activates the solenoid when certain variables are met. Coolant temp is warm enough, enough oil psi, etc.
The MSD switch just turns that bish on or off, regardless of temp etc. U see the lil green plug next to the vtec solenoid? Thats the oil psi sending unit for the P28.
seedlesseg4
10
May 21, 2014 05:00 AM
SOHCpoorguy
Nov 17, 2008 05:21 AM
boosted k20
Jul 21, 2005 07:15 PM
wutupnut
Apr 15, 2005 06:34 PM
green91
17
Dec 29, 2004 03:27 PM
