welding SS??
Old Sep 3, 2004 | 03:09 PM
BlendedEJ8's Avatar
Default welding SS??
what is the difference in welding SS and just steel? what kind of tip would be used. for my DP thanx
Old Sep 3, 2004 | 03:14 PM
david@didrace.com's Avatar
Default Re: welding SS?? (BlendedEJ)
Mig/Tig?
Old Sep 3, 2004 | 06:23 PM
BlendedEJ8's Avatar
Default Re: welding SS?? (10-94-55)
Tig
Old Sep 4, 2004 | 11:23 AM
stizzit's Avatar
You probably want to use 2% thoriated tungston (1/16) for your electrode.
Also you'll need the right filler rod, for 304, you can use something close like 308
stainless won't conduct the heat as well and will expand faster so you won't need to put as much heat into the piece but if you're not carefull it'll get all twisted up on ya.
EDIT: Scarry Post count!
Old Sep 4, 2004 | 01:51 PM
dustin's Avatar
Default Re: welding SS?? (stizzit)
Stainless also crystalizes. You need to backpurge if the weld is structural. If not, it's gonna be ugly on the back side of the weld.
Old Sep 4, 2004 | 04:49 PM
BlendedEJ8's Avatar
Default Re: welding SS?? (dustin)
i not looking for anything hella clean; its gonna be a DP
Old Sep 5, 2004 | 01:00 AM
Ekasey's Avatar
http://www.burnstainless.com
For all your tech article welding needs just clikc on the tech article button
Old Sep 5, 2004 | 04:27 AM
RACEPAK's Avatar
Default Re: welding SS?? (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.burnstainless.com
the link isn't working
Old Sep 5, 2004 | 08:22 AM
Default Re: welding SS?? (RACEPAK)
http://www.burnsstainless.com/
Old Sep 5, 2004 | 08:56 AM
Ekasey's Avatar
hehe sorry it was 3:30 am when i posted that
BTW thanks <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10-94-55 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.burnsstainless.com/
Old Sep 5, 2004 | 10:05 AM
90DALS's Avatar
maybe wrong, maybe not. i used a mig and it came out fine.
Old Sep 5, 2004 | 05:57 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlendedEJ &raquo;</TD></TR><TR><TD CLASS="quote">i not looking for anything hella clean; its gonna be a DP</TD></TR></TABLE>
It's not just for being a clean weld to promote flow, but it will be a much stronger weld. Chances are with the majority of the butt weld tubing cracks you see on this board were due to the fact that the welder was trying to save a little time and money and didn't purge. When tig welding you should back purge with Ar for either mild or stainless as far as I'm concerned.
Old Sep 5, 2004 | 08:25 PM
jojoforhelp's Avatar
Default Re: welding SS?? (SMSP)
Yes a mig can be used. You just need the right gas and wire.
shawn69
Welding / Fabrication
Aug 3, 2008 02:29 AM
22's and Man Boobs
Dec 17, 2007 07:48 AM
shortyz21
Oct 23, 2007 05:41 AM
Ilovemyef9
May 28, 2007 11:44 PM
Justin Olson
Sep 25, 2005 06:00 PM
