Injectors not firing.
Old Sep 3, 2004 | 01:40 PM
colt45.5's Avatar
Default Injectors not firing.
94 ls turbo,
My friend tried to wire his injector resistor box in and install his turbokit on his own with no instruction.
Problem now is ive wired it all back to stock, the fuel rail is getting pressure, the main relay is clicking on the pump, the injectors are getting 12v at the plug, but they arent firing. Ive used 2 well known ecus and still am having no luck. The car turned on one time and just died out. He said it ran for a second and just stalled like it had no fuel. I did take the dizzy out and find the rotor button screw had fallen out and demolished the inside of the dizzy. We replaced it with a new dizzy and still are having the same problems.
The car ran before, he wired the resistor box up, and it never ran again. I replaced everything but the injectors themselves but they worked before.
id be more prone to figure it out but the car was just brought to me as it sets and i have NO idea what was tinkered with.
any tips would greatly be appreciated.
Old Sep 3, 2004 | 01:53 PM
colt45.5's Avatar
Default Re: Injectors not firing. (colt45.5)
Efi main relay even though the pump gets power and primes?
Old Sep 3, 2004 | 02:25 PM
g2turbo's Avatar
up
Old Sep 3, 2004 | 03:57 PM
colt45.5's Avatar
Default Re: Injectors not firing. (g2turbo)
up some more
Old Sep 4, 2004 | 09:36 AM
ccivic's Avatar
up
Old Sep 4, 2004 | 03:45 PM
Fobtions's Avatar
Default Re: (ccivic)
so u have power at the plug ?
did u listen to em with a stethoscope or a screwdriver.?
sounds like the injectors might have gone bad.
Old Sep 4, 2004 | 04:06 PM
colt45.5's Avatar
Default Re: (Fobtions)
im thinking ole boy hooked them up with the resistor box hooked up still and done somthing to them. The plug has 12v at each injector when power is switched on.
Old Sep 4, 2004 | 04:27 PM
colt45.5's Avatar
Default Re: (colt45.5)
nah tested injectors. Pulled rail out and tried starting. Injectors were also substituted with well known ones. Still nothing. The injectors are getting 12v at ignition just seem not to be getting grounded through the ecu cranking over. Ive checked all fuses, substituted 3 well known ecus. New distributor. Its getting spark the injectors just arent firing. Ive also looked at the relay. All terminals are still aok and it clicks 2 times when power is switched on. Fuel pump primes rail, pressure at rail....
Any suggestions im stumped here damnit!
Old Sep 4, 2004 | 10:40 PM
Jago's Avatar
did you check the voltage with a DVOM
Old Sep 5, 2004 | 07:23 AM
colt45.5's Avatar
Default Re: (Jago)
yes i did
Old Sep 5, 2004 | 09:02 AM
ccivic's Avatar
Yeh this sucks....... trying new inj today
Old Sep 5, 2004 | 09:03 AM
ccivic's Avatar
cross your fingers.... this is the last resort!!
Old Sep 5, 2004 | 10:15 AM
colt45.5's Avatar
stoffer read 3 post up u dingus i allready did that. didnt work.
Is it possible for the main relay to go bad yet still turn the fuel pump on?
Old Sep 5, 2004 | 10:18 AM
colt45.5's Avatar
What besides a bad ecu would cause the injector to not ground out to fire?
Like i said i pulled the rail out, with 2 known ecus, 2 sets of injectors, and the injectors will not fire. No fuel is sprayed. They all get power. and all the wiring is back to stock. The relay clicks 2 times when key on, and ive got rail pressure.
Any suggestions would be appreciated. As is ive got a lawn ornament untill otherwise.
Old Sep 5, 2004 | 11:56 AM
blundar's Avatar
my car wouldn't start yesterday. main relay was clicking, no fuel cranking
pulled mainrelay, resoldered all connections, first try starts like a champ
bring me the main relay colt.
Old Sep 6, 2004 | 08:34 AM
ccivic's Avatar
Default Re: Injectors not firing. (blundar)
word ,.. hope thats it. this stuff is frustrating!!!! colt , ill try and get it out of your drivway asap.. call me. peace..
thanx dave for the help soo far.
Old Sep 6, 2004 | 09:22 AM
ccivic's Avatar
Default Re: Injectors not firing. (ccivic)
Trying a friends relay to see if it works. let ya know.
Old Sep 6, 2004 | 10:19 AM
colt45.5's Avatar
relay swap didnt fix it. Still no luck.
Any idears?
Old Sep 6, 2004 | 11:19 AM
colt45.5's Avatar
LOL LOL LOL
I guess the fuel pump installers didnt decide to put the sock mesh deal for the pickup on the fuel pump. He had 1/8 tank, and im sure the pickup was right above the fuel level. Put it on, fired right up.
LOL
Nice one!
PROBLEM SOLVED
Old Sep 6, 2004 | 04:36 PM
ccivic's Avatar
Sooooooooooo great to have her back... thanx again for the help colt.... i learned alot. And from now on .. i do alllllllllll the damn work my damn self!!
Old Sep 6, 2004 | 04:42 PM
colt45.5's Avatar
honda jesus strikes again right gabs.
Old Sep 8, 2004 | 02:57 PM
g2turbo's Avatar
good to hear its running colt
solsquad27
May 15, 2012 11:54 PM
turbo-2nr
Jan 22, 2009 08:10 PM
FastAsleep
17
Aug 28, 2006 04:40 PM
CLE
Jul 13, 2006 02:25 PM
talagangpinoy
May 26, 2004 10:35 AM
