Carbon fiber VIS hatch!!
I have a quick question. the 95 ls teg I used to have had a lever right by the gas door lever on the floor that popped my hatch for me and on my 98 gsr i have to unlock the hatch 1st then pull the handle underneith the hatch to open it up. There is a **** underneither the gas door lever, but i think it is inoperable because when I push or pull on the lever nothing happens I THINK
. So my question is will I be able to use the carbon fiber hatch if i have to use the hatch handle on the oem hatch itself? Or am i out of luck
this will not be cool, because now everytime my car is running i will be forced to turn the ignition off to open the hatch. A hatch release from inside the cabin should be an added feature.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">No, the '98+ Integra has no means of opening the hatch from inside the cabin. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4drewH »</TD></TR><TR><TD CLASS="quote">
no sense on complaining in here, if you want it that bad get one installed. or write a letter to honda
this will not be cool, because now everytime my car is running i will be forced to turn the ignition off to open the hatch. A hatch release from inside the cabin should be an added feature.</TD></TR></TABLE>
Well I just didnt under why they would only have the in cabin release from the year models 94-97.. why would I write honda now they dont even make the g3 integra anymore...? cant change the past
this will not be cool, because now everytime my car is running i will be forced to turn the ignition off to open the hatch.</TD></TR></TABLE>
True, but remember you're installing what is basically a "racing" part, and some sacrifices need to be made. If you want an internal release, you'll have to wire up a new switch to activate the electronic latch.
this will not be cool, because now everytime my car is running i will be forced to turn the ignition off to open the hatch.</TD></TR></TABLE>True, but remember you're installing what is basically a "racing" part, and some sacrifices need to be made. If you want an internal release, you'll have to wire up a new switch to activate the electronic latch.
