Where is this oil leak coming from? (with pics)
Old Sep 3, 2004 | 09:16 AM
jaygtyj's Avatar
Default Where is this oil leak coming from? (with pics)
The car is a 96 Accord. The arrows are pointing where the oil leak begins.
Old Sep 3, 2004 | 09:23 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Where is this oil leak coming from? (jaygtyj)
It's kinda hard to tell but maybe your valve cover gasket.
Old Sep 3, 2004 | 09:30 AM
jaygtyj's Avatar
Default Re: Where is this oil leak coming from? (TouringAccord)
Is that a DIY?
Old Sep 3, 2004 | 09:36 AM
H-T Order of Merit
if it is infact your valve cover, yes. It's a very simple and straight forward thing to do.
edit:
here is a link that might help you if you decide to replace the valve cover gasket, if it doesn't just run a search in the archives for the Accord forum on "valve cover".
https://honda-tech.com/zerothread?id=936749
Old Sep 3, 2004 | 09:59 AM
Turbowa's Avatar
That looks more like the ledge behind the timing belt cover. If that is where the oil is gathering I would be more apt to say that its coming from the cam seal.
Old Sep 3, 2004 | 10:02 AM
H-T Order of Merit
Default Re: Where is this oil leak coming from? (Turbowa)
possibly, deffinately make sure you know what is causing it before going out and buying parts.
Old Sep 3, 2004 | 04:43 PM
accordmurf's Avatar
there was a recall for your car on the cam shaft seal, if thats not it then it probably will be in the future, if its coming from underneath the timing belt cover, then its def cam shaft seal
Old Sep 3, 2004 | 08:16 PM
huyvu90's Avatar
looks like a bad valve cover seal. How many miles are on your car? Did u ever changed the Valve cover seal?
Old Sep 4, 2004 | 02:21 AM
tjohnson329's Avatar
yes accordmurf is right. there is a recall, the balancershaft seal slips and oil comes gushing out. There is a part you can buy to fix this problem it is a very common problem it happened to my car. The recall is over but i'm sure if you didn't lose to much oil you can bring it to honda and have them do a oil change and but the peice on so that the balancershaft seal won't slip no more.
Old Sep 4, 2004 | 04:51 AM
AngryTroll's Avatar
In that location, it's usually the cam seal; the balance shaft seal is lower in the engine.
Old Sep 4, 2004 | 09:49 AM
gofastmobile's Avatar
Default Re: Where is this oil leak coming from? (AngryTroll)
looks like a cam seal to me.....not too hard to fix
Old Sep 4, 2004 | 03:40 PM
fastsohc's Avatar
Default Re: Where is this oil leak coming from? (gofastmobile)
cam seal for sure
Old Sep 4, 2004 | 09:23 PM
huyvu90's Avatar
why is it not hard to fix? Don't you have to remove timing belt or the cam itself? I'd say its a 3-5 hours job.
how many miles are on the car? if less 90k then check it out more to make sure that it is the cam seal. Cam seal doesn't usually leak below 90k.
Maybe i'm just a rookie at cars.
Old Sep 5, 2004 | 04:51 AM
AngryTroll's Avatar
Default Re: (huyvu90)
You remove the valve cover and upper timing cover, mark the cam gear and timing belt with paint, then, remove the gear/belt from the camshaft. I use a ratcheting pulley to hook the cam gear to a inner brace on the hood. It takes <30minutes.
MacR6
Jan 2, 2014 09:35 PM
76 camaro car
Dec 19, 2011 01:30 PM
stupidasso15
24
Oct 5, 2011 12:49 PM
the king.
12
Feb 3, 2009 08:29 PM
Elvis1977
Aug 4, 2005 04:08 PM
