98 honda accord v6 idle surges
Old Sep 2, 2004 | 10:44 PM
tonycvl's Avatar
Default 98 honda accord v6 idle surges
my car just started having idle surges when i start up but only in park or neutral,
but when i drive it has a fast idle at 2000 rpm. it surges from 900 to 2000 rpms fast.
anybody have any ideas? thx
Old Sep 4, 2004 | 04:02 PM
fastsohc's Avatar
Default Re: 98 honda accord v6 idle surges (tonycvl)
is there a check engine light?if not:
first check the throttle cable for proper opperation
then check the throttle body with the engine running by hand to see if it is sticking when released.if it is sticking then first clean it and the intake. or bring it to honda to have it cleaned then if that dosent help you will need to remove and readjust the throttle body according to the factory specs. Check the trrottle body valve for signs of play or binding if there is play then replace the throttle body.
If this dosent work you will need to bring the car to honda to have someone properly diag,, the car with the pgm tester.
Old Sep 4, 2004 | 04:05 PM
AngryTroll's Avatar
You need an Idle Air Control Valve. Eventually, you will set a P0505.
At this time, I have a new, Honda OEM part available, but it's on Ebay, now; so it may go anytime.
Jack jaxz
Engine Management and Tuning
Mar 30, 2016 04:15 AM
toby8806
Apr 27, 2009 02:00 PM
BallerAccord
Mar 14, 2008 11:29 AM
Ink00
Dec 24, 2002 01:15 AM
f15hman
Nov 21, 2002 12:43 AM
