ctr or itr pistons for gsr
Old Sep 2, 2004 | 05:42 PM
shomershavis's Avatar
Default ctr or itr pistons for gsr
Is there any difference in these pistons? I always hear people saying ctr for integras, but are they a direct fit and is there really a noticable difference in the two.
Old Sep 2, 2004 | 06:11 PM
1stGENGSR's Avatar
Default Re: ctr or itr pistons for gsr (shomershavis)
CTR yields a higher compression than ITR, both can fit a stock bore, or oversize up to half a mm..........Check this link out to see the difference:
Follow the instructions and it will show you the different compression set-ups, just put your head, block,etc., and the piston you'd like to try...,click on the help at the bottom and it will tell you what is what, ex. PCT=CTR piston http://technet.ff-squad.com/cr-calculator.htm
Old Sep 2, 2004 | 08:04 PM
zad5's Avatar
some dont like the ctr because of the valve relief and weight of the piston (due to the higher dome). it also doesnt allow the same amount of air fuel into the motor theirs a word for this but i forgot. some get jdm itr piston and shave the head accordingly so that the compression matchc the cam accordingly. but people build differently. the ctr piston are proven to work no doubt about it many dyno ctr with skunk2 stage 2 200whp 205 with toda c but he milled the head also. ive seen other also it makes powaA.
Old Sep 2, 2004 | 09:54 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shomershavis &raquo;</TD></TR><TR><TD CLASS="quote">Is there any difference in these pistons? I always hear people saying ctr for integras, but are they a direct fit and is there really a noticable difference in the two.</TD></TR></TABLE>
CTR or ITR? how about none and save some more money for better?
your is a GSR....get b16's Piston...compression get higher for cheap...
if not get aftermarket piston...CTR or ITR aint much better than GSR anyway...why bother...beside they're cheap, cheap=cheap power....can't get away with that...if you planning to get those piston why didn't you get type r engine at first anyway...
if you are trying to up[grade GSR to Type R...Gsr doesn't lose to type R that much man...save mone ang et J.E
Old Sep 3, 2004 | 01:29 AM
xplanetearth420x's Avatar
Default Re: ctr or itr pistons for gsr (yeegsr)
i just got ctr pistons and the itr pistons fit right in i believe but i had to get a .010 bore to fit my ctr pistons
Old Sep 3, 2004 | 02:22 AM
OLM-02R's Avatar
just get ctr piston...for more cr...you might need the extra cr later on n e ways when you go all out...
Old Sep 3, 2004 | 05:57 AM
topspeed86's Avatar
Try to find a set of JDM P30's the skirts are coated and the dome is smaller than CTR but bigger than ITR. Inline4 sells them.
Old Sep 3, 2004 | 03:27 PM
1stGENGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
What the hell are you talking about? How are OEM Honda pistons equivalent to cheap power? Honda parts are usually considered 'best' for a Honda motor. The comp. ratios of the type R slugs are significantly higher thus creating more power with a high performance valvetrain and a little tuning. The fact that they are 'affordable' makes them even more desirable for a high performance N/A motor, unlike a B18C5 (type R) which can cost a small fortune 'IF' you can find one...............
Old Sep 3, 2004 | 04:04 PM
Default Re: ctr or itr pistons for gsr (1stGENGSR)
so i will need to bore the head to fit ctr's? I am planning on getting either buddy club spec3's or skunk 2s stage 1 or 2 (not sure since its a daily driver), but i dont want to have to go totally extreme, but i do want to hit the 200 whp mark.
Old Sep 3, 2004 | 10:19 PM
1stGENGSR's Avatar
You only need to bore if your cylinders are out of round, or have scratches or scuffs in them. Otherwise just go with stock bore (81mm). You will have to have the small end of the rods slightly machined to fit on the CTRs, but it's fairly inexpensive..........
Old Sep 4, 2004 | 09:30 AM
JDM4DR.GSR's Avatar
big difference extreme compression difference,. i also have a perfect set up for you i have brand new .20 overbored ctr pistons, wrist pins and rings for sale....these parts are brand new in the box....i am trying to get $350 for them plust shipping
i also have crower 403's brand new in the box...they retail for almost 800 and i am looking to get $650 plus shipping so let me know...pm me or e-mail me at jdm4_dr@yahoo.com
Old Sep 4, 2004 | 10:19 AM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1stGENGSR &raquo;</TD></TR><TR><TD CLASS="quote">You only need to bore if your cylinders are out of round, or have scratches or scuffs in them. Otherwise just go with stock bore (81mm). You will have to have the small end of the rods slightly machined to fit on the CTRs, but it's fairly inexpensive..........</TD></TR></TABLE>
Anytime you are changing rings, IE new pitsons you need to get the cylinders honed so that the rings seal properly, otherwise you'll be smoking the **** out of the person behind you in a few thousand miles.
Bedgoodmrb
Dec 20, 2009 07:36 PM
gsr96cx
Jun 20, 2008 04:06 PM
iHeartIntegraDA
Mar 17, 2005 04:01 PM
duRritztiNy
35
May 16, 2003 10:36 PM
10seconds
Jul 3, 2002 12:22 AM
