CTR or ITR pistons?
Old Mar 17, 2005 | 03:48 PM
iHeartIntegraDA's Avatar
Default CTR or ITR pistons?
Does CTR pistons give you more compression than ITR? Which has a bigger dome on the piston heads?
Old Mar 17, 2005 | 03:56 PM
LSTEG96's Avatar
Default Re: CTR or ITR pistons? (iHeartIntegraDA)
ctr gives you higher compression
so, ctr has higher dome
Old Mar 17, 2005 | 04:01 PM
DOHCsideracing's Avatar
Search is your friend... This is covered almost once a week, because noob's don't search first.
Here is a sticky from the All-Motor forum that answers your question and more.
https://honda-tech.com/zerothread?id=717928
That said, CTR will yield you the highest CR (~12.9:1 on a GS-R motor) of the Type R stuff. JDM ITR's will yield you ~11.5:1 (my pick for reliable daily street duty...), and USDM ITR's will yield you ~11.0:1 (all in a GS-R motor (or B18CX with a GS-R head))
Read the reference post, though, as there is a lot of good info in there.
Welcome to H-T, and I hope others don't burn you too bad for not searching (hint: activate flame suit now ...).
Adrian
gsr96cx
Jun 20, 2008 04:06 PM
CircuitFG
Jul 5, 2003 09:01 AM
duRritztiNy
35
May 16, 2003 10:36 PM
Inthered
Nov 20, 2002 07:39 PM
X2BOARD
Aug 9, 2001 11:00 PM
