immoblizer to PCM signal error problems after VAFCII
Old Sep 2, 2004 | 05:29 PM
GSR GRN97's Avatar
Default immoblizer to PCM signal error problems after VAFCII
Had a VAFCII installed and ever since I have had CEL P1259 coming on...I was told by the acura dealer it was a grounding problem engine ground/ battery terminal loose causing voltage irregularities so I fixed any possible problems with that. I called APEXi directly they swore up and down to check the wiring and so I did...same stuff. ALL I WANT IS A CAR THAT RUNS RIGHT! Help me out please....
Old Sep 5, 2004 | 10:00 AM
GSR GRN97's Avatar
Default Re: immoblizer to PCM signal error problems after VAFCII (GSR GRN97)
Anyone????? I can't even get through staging at the track without the CEL coming on!!!!!!
Old Sep 5, 2004 | 03:06 PM
PHiZ's Avatar
Sounds like you wired it wrong.
-PHiZ
Old Sep 7, 2004 | 10:27 AM
GSR GRN97's Avatar
Default Re: immoblizer to PCM signal error problems after VAFCII (PHiZ)
thanks, it's going back to the shop on thurs we'll see what happens after that!
fuzzysig
Acura TL, RL & ZDX
Oct 18, 2016 01:41 PM
siregcivic
Sep 27, 2007 09:46 PM
HondaPH22
Jul 17, 2006 09:26 PM
tianporn
21
Jul 15, 2005 06:37 AM
RineRacing
Apr 14, 2003 05:53 AM
