pls help in swap
i just did a swap in my crx....for some reason it's only firing in number 4 cylinder....pls someone help me...ls block with gsr head obd0 ecu obd0 dizzy
DX CRX?
Did you use your stock engine harness?
Check your wiring for the distributor.
Check wiring for the injectors.
What injectors did you use?
Are you running the resistor box???
yeah i did all the conversion right.....last week was running but in a low idle...all the cylinder is firing but now i'm tryin to start only 4 is firing
cannouu
Engine Management and Tuning
Jun 28, 2012 10:17 AM
B18C1EF
10
Mar 20, 2006 04:12 PM
solohatch
Jul 1, 2005 12:13 AM
