HONDATA REFLASH AND TRANSMISSION QUESTION?
Old Sep 2, 2004 | 03:18 PM
ALTERED SI's Avatar
Default HONDATA REFLASH AND TRANSMISSION QUESTION?
does anyone have problems with the tranny after getting hondata, like grinning noise from 2nd gear after 7700 rpm's going to 3rd anybody thanks...
Old Sep 2, 2004 | 05:11 PM
S-fiend's Avatar
Default Re: HONDATA REFLASH AND TRANSMISSION QUESTION? (ALTERED SI)
Are you engaging the clutch completely before shifting?
Because if the clutch isn't fully engaged at such high rpm's then it will grind going in.
Made sure the clutch is to the floor before ripping second.
Old Sep 3, 2004 | 12:27 AM
silver comet's Avatar
Default Re: HONDATA REFLASH AND TRANSMISSION QUESTION? (S-fiend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S-fiend &raquo;</TD></TR><TR><TD CLASS="quote">Are you engaging the clutch completely before shifting?
Made sure the clutch is to the floor before ripping second.</TD></TR></TABLE>
definately. why 7700?
Old Sep 3, 2004 | 03:56 AM
ALTERED SI's Avatar
Default Re: HONDATA REFLASH AND TRANSMISSION QUESTION? (silver comet)
i went to the dealers
before i have hondata done, for the same problem they told me the same bs they tell everybody else ''the transmission is ok no problems when i told then that it gring at 6800 rpm's the idiot told me ''why r u shifting at such high rpm's ? the car is not made 4 that!!! i want to punch the his lights out... anyway good luck to all and thanks... dealers suck!!
Old Sep 3, 2004 | 05:54 AM
t o m's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALTERED SI &raquo;</TD></TR><TR><TD CLASS="quote">i went to the dealers
before i have hondata done, for the same problem they told me the same bs they tell everybody else ''the transmission is ok no problems when i told then that it gring at 6800 rpm's the idiot told me ''why r u shifting at such high rpm's ? the car is not made 4 that!!! i want to punch the his lights out... anyway good luck to all and thanks... dealers suck!! </TD></TR></TABLE>
wow i think you should have walked the dealer guy to your car and showed him ur tach. and said "hey dumb *** look it goes to 9K"
Old Sep 3, 2004 | 05:57 AM
civileng25's Avatar
Default Re: HONDATA REFLASH AND TRANSMISSION QUESTION? (integra type s)
Mine grinds without hondata if I try to speed shift. I just stick to granny shifting now.
Old Sep 9, 2004 | 10:17 AM
myst's Avatar
i had my 3rd gear synchro go with only 8,000 miles on my car. took it to the dealership and they fixed it under warranty.
91tegra07
Feb 25, 2008 03:00 PM
delsolio1996
Apr 10, 2006 01:54 PM
KrispyKreme
22
Jan 10, 2005 11:57 PM
CRXed
May 12, 2004 02:24 PM
steebypue
Apr 24, 2003 09:08 AM
