is the knock pin (D3) supposed to be grounded?
Old Sep 2, 2004 | 02:13 PM
thad
Guest
Posts: n/a
Default is the knock pin (D3) supposed to be grounded?
i'm getting a code 23 which never happened before, i switched from a poormans R with jdm P30 to a GSR with OBD 1 P72 i was checking my wiring to see in i had continuity from the plug to the ecu and i showed 12v when i probed the knock wire and the positive, i thought it might have grounded out somewhere so i check the pin from the ecu, with only the D plug disconnected i got -12v on D3 and -8 on the surrounding pins,
Old Sep 2, 2004 | 05:49 PM
thad
Guest
Posts: n/a
Default Re: is the knock pin (D3) supposed to be grounded? (thad)
really need to know cause i'm going to the smog reff soon and i can not have any CELs at all, if anyone could just put a voltmeter to the end of the knock conector, i would really appreciate the help.
Old Sep 3, 2004 | 12:34 PM
thad
Guest
Posts: n/a
Default Re: is the knock pin (thad)
really need info
longshot
Aug 7, 2008 01:25 PM
FunIntegras
12
Sep 27, 2005 07:18 PM
99hatch
Jan 8, 2005 02:52 PM
13secondmonster
Dec 10, 2004 02:25 PM
SC0TT
Sep 16, 2003 01:04 PM
