Need help with my setup!!!
Old Sep 2, 2004 | 12:13 PM
hovic's Avatar
Default Need help with my setup!!!
Hi guys..
I´m new with all motor and I´m planing to build a All Motor B16 engine. I´ve got JE 12,5:1 Pistons. I´m planing to go with the full Jun valvetrain and Jun 3 cams.
The first question is:
Can I go with a blockguard or is it nesesarry to sleeve the block with that high compression ratio? (pistons are stock zize!)
2nd.
What rods do you recommend??
3rd
What kind of oilpump do I need?
What else is recommended for theese setup?!
Thanx
Old Sep 2, 2004 | 12:36 PM
WAFFLES's Avatar
Default Re: Need help with my setup!!! (Manuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">oem gsr blockgurd oem vtec part's work good oil pump water pump etc</TD></TR></TABLE>
GSR does not come with a block guard.
Old Sep 2, 2004 | 04:08 PM
hovic's Avatar
Default Re: Need help with my setup!!! (WAFFLES)
ok thanx for reply.. I want to rev a bit higher.. aprox 10k or a bit mor if possible. So whats about the rods?? I don´t think they will be good for this...
Old Sep 7, 2004 | 01:06 PM
hovic's Avatar
Default Re: Need help with my setup!!! (hovic)
ok I´ve searched a bit and think I´ll go with probe rods :-) But I don´t know where to buy nhem any ideas???
Also I have to put new rod and crank bearings into my engine and I´ve seen the king bearings at ebay. But I´ve never heard something about them. I searched alot here but no informations What do you think about them? OEM is too expencive here in germany...
Old Sep 11, 2004 | 08:38 AM
hovic's Avatar
Nobody Whats about the probe rods????
Old Sep 12, 2004 | 03:48 AM
hovic's Avatar
Thanx man
itz_nij
Apr 1, 2004 10:21 PM
J22si
11
Jan 25, 2004 01:01 PM
dEtSoOb
Jan 22, 2004 01:38 PM
spraa
Dec 29, 2003 05:57 PM
Mark
Aug 16, 2003 11:19 AM
