95 Accord LX speaker question here
the back of the LX has a stock hole made for a 6x9, but some accords came with a plate adapter and 6.5" speakers, just get rid of th eplate adapter and throw in some 6x9s
Modified by puma1077 at 10:14 PM 9/3/2004
Aight then 6 x 9 will fit in my back den. I thought that hole looked big enough for them, but didn't notice that big *** piece of metal holdin it in, and wasn't sure if it would come out. But 6 1/2's should fit in my front door speakers slots as well right?
By the way i got a new head unit, as well as two 600 watt subs, with a 1600 watt amp. Will this blow my speakers?
Lastly its not hooked up yet, will i be better off tryin to install it all myself or paying a professional? i got door speakers front and back. 2 subs, amp, capacitor, head unit, and wiring kit. I've never hooked anythin up befor but it seems simple enough. would i be better off payin someone of tryin on my own. and can somone post explanation on how to do it if its easy.
By the way, i think i have 5.25 rear speakers in there. But if i want to put in some 6 x 9's will i need to buy a new plate adaptor for them. or will they fit in the stock hole?
as long as u power ur speakers with ur head unit, nothing should blow
if you remove the plate in the back im 99% sure a 6x9 will drop right i could be wrong, but you can always just try it out
about the installing thing, if you are not comfortable installing ur system, then dont do it, if you think you can, then go for it. Every professional installer out there didnt know anything at one point.
Just remember to disconnect ur battery when u start, and dont reconnect it till you are 100% sure everything is hooked up right
