320cc injectors sufficent for built crvtec?
Old Sep 2, 2004 | 10:33 AM
captainjdog's Avatar
Default 320cc injectors sufficent for built crvtec?
Do you think 320cc injectors are sufficient for a B20B Sleeved
I/H/E, B16a P&P head, Skunk 2 valvetrain/stage 2 cams @ 9.4:1 comp?
In the future the motor for my crx will be turbo but for now I just want to break
it in all motor. I'll find out once i get to the dyno but i'd hate to get charged and then be told the injectors are insufficient size.
Thanks,
Old Sep 2, 2004 | 12:08 PM
Rollo Lawson's Avatar
hell yeah, that's plenty.
Old Sep 2, 2004 | 12:38 PM
AllMTRWH0R3's Avatar
Default Re: 320cc injectors sufficent for built crvtec? (captainjdog)
in a fully built high compression engine those injectors would lean out by the amount of gas ( lets say 91) needs to be put to make power but, since you are going turbo it might be you will need 440 or high depending on how your setup will be like? ( again I dont know what kidn of turbo you have and what is done the the head and such. You should be fine but before you get your turbo and not waste money on someone telling you well your injectors maxed out again get soem bigger ones and a bigger fuel pump as well.
happy tuning
Ernie
Old Sep 2, 2004 | 04:39 PM
Default Re: 320cc injectors sufficent for built crvtec? (allmtrwhore2)
Ok thanks guys,
Fuel pump / system is upgraded already, forgot to post that. I just wanted to be safe for breakin, I just havn't decided what size injectors / turbo size im gonna go with yet, therefore didn't want to go runout and buy some insufficient ones just so I could run my motor around N/A.
Thanks again,
TooSmooth
Dec 21, 2010 06:05 AM
Marc_Smith
Sep 23, 2009 07:41 AM
bigtom388
Oct 16, 2008 04:33 PM
spooniq
Honda S2000
Jan 11, 2006 04:19 PM
yellowbuffalo
Dec 9, 2002 03:11 PM
