DSM Injectors in 6th Gen Accord
I'm putting the DSM 450's in my 99 Accord i4 tonight and I have the injectors, 4 10-ohm 10 watt resistors, and 4 injector seal kits from NAPA part #2-12089. Do I need anything else? Do I even need the seal kits? Thanks.
I hope you have some way to control the injectors... aside from that, you are SET!
I have the same setup in my 6th gen. You'll need to dremel out the injector seals - the round sander dremel attachment makes the inner hole the EXACT right size for the DSM's. HTH
Charliehondaman
Sep 19, 2004 09:25 PM
