hard to shift into 1st
Old Sep 2, 2004 | 12:01 AM
pbizzlegsr's Avatar
Default hard to shift into 1st
well lately for some reason ive been having trouble shifting into first from a stop.it would feel like it goes halfway into first but not all the way where its engaged..i would then have to go back into neutral and clutch it and then go back into 1st for it to work..that or go into another gear and then go into first...i know it normal if it wont go into 1st once in a while but this happens at least 5 times a day..whats my problem?
Old Sep 2, 2004 | 12:25 AM
Accord2NR's Avatar
Default Re: hard to shift into 1st (pbizzlegsr)
happened to me too, also with reverse and wen i tried to go anyways it would either rev or grind..... i never found out, mabe a clutch problem
Old Sep 2, 2004 | 12:43 AM
SivikHatch's Avatar
Are you making sure your pressing the clutch all the way down? Also try checking your clutch fluid.
Old Sep 2, 2004 | 12:52 AM
pbizzlegsr's Avatar
Default Re: hard to shift into 1st (SivikHatch)
yea i step on the clutch all the way..clutch was changed 2k ago..
Old Sep 2, 2004 | 01:15 AM
Transport's Avatar
thats how all honda and acuras are. 1st and reverse. when that happens, put it back into neutral, let go of the clutch then press down on the clutch again and then pop it back into 1st or reverse. if that dont work, go into 2nd then go back into 1st. for reverse, go into 1st then go back into reverse. those tips usually does the trick for me...
Old Sep 2, 2004 | 09:41 AM
Two_K Si's Avatar
Default Re: hard to shift into 1st (Gr8GrZ)
Make sure you come to a complete stop. I have the same problem if i am rolling oh so slightly. Try to blip the gas while putting it in first also.
Old Sep 2, 2004 | 09:44 AM
b18punk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gr8GrZ &raquo;</TD></TR><TR><TD CLASS="quote">thats how all honda and acuras are. 1st and reverse. when that happens, put it back into neutral, let go of the clutch then press down on the clutch again and then pop it back into 1st or reverse. if that dont work, go into 2nd then go back into 1st. for reverse, go into 1st then go back into reverse. those tips usually does the trick for me...</TD></TR></TABLE>
^^^this works almost every time
or sometimes while pushing it into first---if it gets stuck part way, let up on the clutch a little bit and it should go in
Old Sep 2, 2004 | 10:02 AM
PLAGUED_DB7's Avatar
Default Re: hard to shift into 1st (b18punk)
I just had that problem fixed a while back. my clutch cylinder, and clutch were going...now I shift like new again!
Old Sep 2, 2004 | 10:13 AM
qcktegls's Avatar
thats the only way i can get into first from a slow rolling stop or even a stand still.
Old Sep 2, 2004 | 10:21 AM
92vx6's Avatar
i have the same problem sometimes. i have to clutch in then rev up a little to get in reverse. my car has 118k so i prolly need a new clutch. Just dont feel like spending so much $.
Old Sep 2, 2004 | 10:39 AM
Revolver's Avatar
Old Sep 2, 2004 | 11:41 AM
smemts's Avatar
werd
Old Sep 2, 2004 | 01:28 PM
foolintherain617's Avatar
Default Re: hard to shift into 1st (smemts)
I know that it is hard going into reverse in hondas as a saftey precaution to prevent going directly from 5th to reverse, which would suck. I find 1st hard to go into occasionally unless im at a complete stop, not just a roll through. Which makes sense then because you would almost be in second if you didnt stop all the way.
Old Sep 2, 2004 | 02:51 PM
Vtecfool's Avatar
Default Re: hard to shift into 1st (foolintherain617)
yea, once in a while it won't go into 1st or Reverse for me. I usually just put it back to neutral and let off the clutch and try again, always works for me!
Old Sep 2, 2004 | 07:32 PM
sooo_slow's Avatar
New User
Default Re: hard to shift into 1st (Vtecfool)
I used to have the same problem..but mine was soo hard to get into 1st..i had to really jam it..then found out what the problem was...synchro's...
Old Sep 2, 2004 | 07:36 PM
iixerOii's Avatar
Default Re: hard to shift into 1st (It_aint_stock)
I have all the listed problems above as well. I think my transmission needs a overhaul.
ThaEfSwap
Nov 29, 2011 06:37 PM
Cypher0117
16
Dec 9, 2009 08:36 AM
FRKWOO
Jan 14, 2009 07:00 AM
MiraiZ
Aug 12, 2003 06:18 PM
FlipboiGSR
Sep 12, 2001 09:07 PM
