Timing Belt Cover b20 vtec ?
Old Sep 1, 2004 | 11:21 PM
96MidoriHatch's Avatar
Default Timing Belt Cover b20 vtec ?
Trying to figure out if you can use a timing belt cover on b20 vtec. (lower portion)I've been searching and everyone has a different opinion. Some say that you can't use a timing belt cover, some say that it has to be b20, some that it has to be gsr (BTW its a si head). Just wondering if anyone here has a timing belt cover on thier b20 vtec
Old Sep 1, 2004 | 11:26 PM
Sack Master's Avatar
Default Re: Timing Belt Cover b20 vtec ? (96MidoriHatch)
I have an LSVTEC and I use a gsr timing cover on it. It all fit perfect. I think those blocks are all the same b18/20. I just don't know if the upper portion of a gsr would match the lower of a b20. Try it and find out. If you have the cover see if it fits. It's only a pulley and a couple belts.
Old Sep 1, 2004 | 11:32 PM
Default Re: Timing Belt Cover b20 vtec ? (Sack Master)
haha nice sig
Old Sep 2, 2004 | 08:46 PM
any one else?
Old Sep 2, 2004 | 10:52 PM
integramic's Avatar
I have two b20's and ls's and a gsr. The b20 cover is different unless someone changed the oil pump(Some take it off because the oil pump gear inside is the same one as a type r. Most people think the oil pumps are the same but the gear is wider in the b20 and type r). I just had to get a cover for the b20.
Old Sep 3, 2004 | 11:05 AM
Default Re: (integramic)
okay so it does have to be a b20 cover?
Old Sep 3, 2004 | 01:47 PM
integramic's Avatar
yes
Old Sep 4, 2004 | 12:14 AM
just ordered the cover and the stupid gasket from honda today
MegustaVtec
Jan 31, 2014 03:06 PM
Tarmac Junkie
Oct 2, 2006 09:07 AM
Hoosier Daddy
Dec 29, 2003 02:45 PM
mugenintegra16
Feb 10, 2003 11:19 AM
