Huge loss of power
Old Sep 1, 2004 | 09:54 PM
Donkey85's Avatar
Default Huge loss of power
okay guys and or gals i'm in need of some help.
i have my 89 hatch with a JDM D15b i am having a problem with it. i was comming home from work one day and all the sudden it had no power. It was very slow, like normaly after 3k it would pull hard all the way to redline and would rev very freely. now it stopped and dosent rev as good. it idle's perfect with no problems, i checked for compression its perfect in all 4 cyls. i put new cap,rotor,plugs and still no luck. it cant be the coil or the ignitor because i swapped dizzys off another one that works fine and still no luck. i also check timing and that checks in perfect. its just running like a dog. if anybody can help me out it would be greatly appreicated. thanks in advance
Old Sep 1, 2004 | 10:25 PM
eda6's Avatar
Default Re: Huge loss of power (Donkey85)
Change the fuel filter if problem returns check the fuel pump.
Old Sep 1, 2004 | 11:35 PM
Fobtions's Avatar
Default Re: Huge loss of power (eda6 hb)
make sure u have the right injectors. ive seen people use the obd1 style .
they work for a lil bit then die.
just take a stethoscope and listen to the injectors.
Old Sep 1, 2004 | 11:47 PM
hahagasdcrx's Avatar
Default Re: Huge loss of power (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">make sure u have the right injectors. ive seen people use the obd1 style .
just take a stethoscope and listen to the injectors.</TD></TR></TABLE>
thats what im thinking
Old Sep 2, 2004 | 11:57 AM
Donkey85's Avatar
Default Re: Huge loss of power (hahagasdcrx)
fuel filter is less than a month old, and i'm currently running dual point not multi point and its been that way. since i put it in. any more help is greatly accepted thanks so far!
Old Sep 2, 2004 | 09:25 PM
Donkey85's Avatar
come on people i need help!!!!! i need to get this cranky beast fixed this weekend. somebody help a fellow honda owner in need
Old Sep 3, 2004 | 04:00 PM
Donkey85's Avatar
anybody have anymore ideas?????
Old Sep 3, 2004 | 04:06 PM
4drEF's Avatar
Keyboard Humorist
Air filter?
Plugged cat?
Bad plug wires?
T-belt jumped a tooth?
No idea.
Old Sep 3, 2004 | 09:51 PM
Donkey85's Avatar
Default Re: Huge loss of power (4drEF)
air filter-no i have a CAI and its good
plugged cat- havent checked that yet will do tomm. what causes a cat to plug up?
plug wires- they are pretty new they are taylor race pro 10.4mm
t-belt- i checked timing and that perfect so cant be off a tooth.
also does anybody know how i can check fuel pressure since i dont have a fuel rail because of the dual point injection??
Old Sep 3, 2004 | 09:57 PM
Fuzion's Avatar
i would check all your grounds. and/or fuel system
Old Sep 3, 2004 | 10:46 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donkey85 &raquo;</TD></TR><TR><TD CLASS="quote">also does anybody know how i can check fuel pressure since i dont have a fuel rail because of the dual point injection??</TD></TR></TABLE>
Get a fuel pressure gage and install on outlet of your fuel filter.
Old Sep 4, 2004 | 01:59 AM
murmur9's Avatar
Yea, check your grounds, take a steel brush or some 80 grit sand paper and clean the surface. also take your heat shield off and see if you have some cracks on your Exaust manifold....one of my cars did the same thing...**** ticked reall bad like the valves were bent.....turned out to be as big crack. it was on a gsr and i couldnt figure out why i was runing 16's lol
Old Sep 4, 2004 | 10:25 PM
Donkey85's Avatar
Default Re: Huge loss of power (murmur9)
okay heres a new update i took off the cat to have a look and it wasnt clogged. i am still stumped as to why its still funning so slow. it really strains to get above 6k which it used to do with ease. anymore input would be great
Old Sep 6, 2004 | 09:11 PM
Donkey85's Avatar
BUMP
somebody has got to have an answer for me
Old Sep 8, 2004 | 10:17 PM
Donkey85's Avatar
c'mon you guys with all the great honda gurus we have here nobody has a clue?
eg93LS
Jan 26, 2010 12:51 PM
asmallsol
Sep 4, 2006 05:55 PM
michael_c
Aug 21, 2006 09:16 PM
Magaton00si
21
Apr 16, 2006 08:55 PM
JTCdudeman
Aug 17, 2005 07:14 PM
