another problem in my swap!
Old Sep 1, 2004 | 06:48 PM
type-t's Avatar
Default another problem in my swap!
ok here it goes....
92' accord w/ jdm h22a
i fixed the dizzy problem ive been having it turned out that the ecu fuse was out..ok replaced that...the car turned on and now im having a problem during idle and acceleration...the car sounds like this vrooooom put put put put vroo put vroom put put put...like it running out of air or its choking on too much gas...the car was running fine the first time i ever turned it on which was right before the ecu fuse went out....oh yeah when i first turned it on it was on fore about 1 hour and then it started sounding like **** vroom put put vroom put wroom put put ...wtf is it now..i think ive had the worst swap experience ever
Old Sep 1, 2004 | 06:57 PM
BlazeTeck2000's Avatar
Default Re: another problem in my swap! (type-t)
did you check if the igntion coil is good ?? maybe its the fuel fillter ...that fixed mine really quick
Old Sep 1, 2004 | 09:16 PM
type-t's Avatar
Default Re: another problem in my swap! (BlazeTeck2000)
yeah the ignition coil is brand new...the fuel filter is located near the vacuum canister right?
Old Sep 2, 2004 | 08:33 PM
gimme_h22's Avatar
i'm sorry, does ur sig say you are putting a turbo whistle in your muffler? something like that really has no performance gains, am i correct?
Old Sep 2, 2004 | 08:34 PM
type-t's Avatar
Default Re: another problem in my swap! (gimme_h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gimme_h22 &raquo;</TD></TR><TR><TD CLASS="quote">i'm sorry, does ur sig say you are putting a turbo whistle in your muffler? something like that really has no performance gains, am i correct?</TD></TR></TABLE>
turbo whistle will give you an extra 20hp to the wheel
Old Sep 2, 2004 | 08:53 PM
gimme_h22's Avatar
what does it do? i'm unaware of turbo whistles and if 20 whp is that easy, i want in on it.
Old Sep 2, 2004 | 11:28 PM
H2290's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type-t &raquo;</TD></TR><TR><TD CLASS="quote">
turbo whistle will give you an extra 20hp to the wheel</TD></TR></TABLE>
Type-T, you need to stop playing with this guy. I think you're actually confusing him. Sorry man, no gains from turbo whistles or bullet shot stickers either. If only it were that easy.
Also, when you replaced the ECU fuse did you let the car idle and stuff to reset itself. If you immediately started accelerating and stuff it might not be able to get it's baseline right. Try resetting it and waiting a couple of minutes before touching anything.
Kanekz13
Dec 31, 2011 02:29 PM
BlueRSTEg
Jan 10, 2010 10:13 PM
slowteg90
Feb 18, 2008 12:25 PM
mafia
Nov 5, 2006 06:26 PM
asmallsol
Sep 4, 2006 05:55 PM
