New engine... won't start now. Will pay if someone tells me whats wrong. NO JOKE!
Old Sep 1, 2004 | 06:01 PM
J-Brooks's Avatar
Default New engine... won't start now. Will pay if someone tells me whats wrong. NO JOKE!
Well I burnt a valve bought a month ago on the way to a honda-tech meet. I start putting another LS motor in my car saturday and finished last night. The car started up and seemed to run ok. I drove it very little sorta easing into. It is turbo. I have a new wastegate spring also and I did forget to reset the boost controller. So when I got on it one time... it seem to what I think was detonation or something. then the car cut off.
Now all it will do is turn over. It gets spark. It has fuel. New cap and rotor, new coil. NO CEL!
WHATS THE problem.
If you guess it right I will paypal you $10. NO JOKE. I am desperate to get my car running. And I figure maybe I will get some more responses if I offer $10.
Thank ahead of time
Old Sep 1, 2004 | 06:29 PM
93civicEX's Avatar
check the compression, It takes spark, fuel, and compression to get a running engine
Old Sep 1, 2004 | 06:32 PM
J-Brooks's Avatar
Default Re: (93civicEX)
What would cause me to loose compression in all cylinders? Or would loosing compresion in just one cylinder cause the engine not to run?
Old Sep 1, 2004 | 06:59 PM
93Civac's Avatar
Try checking your timing. May help. You also have to have air to have a running engine, so you might make sure nothing is clogging up your intake or possily something in the throttle body. I dunno, just throwing out some possibilities.
Old Sep 1, 2004 | 09:18 PM
J-Brooks's Avatar
Default Re: (93Civac)
Compression is going from #1-4 130, 165, 160, 160
Modified by J-Brooks at 6:36 AM 9/2/2004
Old Sep 1, 2004 | 10:10 PM
Droppedatbirth!'s Avatar
Default Re: (J-Brooks)
ditto check your timing has to be it
Old Sep 1, 2004 | 10:40 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Brooks &raquo;</TD></TR><TR><TD CLASS="quote">I burnt a valve bought a month ago on the way to a honda-tech meet.
How do you tell if you have a burnt valve? Can you tell while driving? What causes it?
i'm trying to get edumacated
Old Sep 1, 2004 | 11:01 PM
Sack Master's Avatar
Default Re: (eda6 hb)
Check your map sensor, also check to see if you possibly blew out something. Maybe your iac or something along those lines.
How do your spark plugs look?
Old Sep 2, 2004 | 01:17 AM
SivikHatch's Avatar
Default Re: New engine... won't start now. Will pay if someone tells me whats wrong. NO JOKE! (J-Brooks)
Check your underhood fusebox. In there take a look at the fuse that is labeled FI E/M. If its burnt, that should be why your car keeps turning over but wont start.
Modified by SivikHatch at 4:27 AM 9/2/2004
Old Sep 2, 2004 | 03:38 AM
J-Brooks's Avatar
Default Re: New engine... won't start now. Will pay if someone tells me whats wrong. NO JOKE! (SivikHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 hb &raquo;</TD></TR><TR><TD CLASS="quote">
i'm trying to get edumacated </TD></TR></TABLE>
Took the head off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Check your map sensor, also check to see if you possibly blew out something. Maybe your iac or something along those lines.
How do your spark plugs look?</TD></TR></TABLE>
iac?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SivikHatch &raquo;</TD></TR><TR><TD CLASS="quote">Check your underhood fusebox. In there take a look at the fuse that is labeled FI E/M. If its burnt, that should be why your car keeps turning over but wont start.
will do, just need to find a fuse box cover
Old Sep 2, 2004 | 09:18 AM
senpai's Avatar
You broke ringlands and/or rings
Old Sep 2, 2004 | 10:36 AM
Default Re: (maztur)
Idle air control. Sits on the back of the intake manifold.
Old Sep 2, 2004 | 11:23 AM
J-Brooks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">You broke ringlands and/or rings </TD></TR></TABLE>
you sure bought that?
Old Sep 2, 2004 | 12:43 PM
SivikHatch's Avatar
will do, just need to find a fuse box cover</TD></TR></TABLE>
Its the first fuse(15) on the top left next to the backup fuse(7.5)
Old Sep 2, 2004 | 01:50 PM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Brooks &raquo;</TD></TR><TR><TD CLASS="quote">So when I got on it one time... it seem to what I think was detonation or something. then the car cut off.
When you crack ringlands, it's very hard to start the car (if it even starts.) Which cylinder was low on compression?
nic0h
Jun 23, 2010 07:51 PM
honda_prelude_jay
Jan 3, 2009 03:36 PM
huepowered
Feb 20, 2007 12:13 PM
roberts02
Jun 11, 2004 01:41 PM
