IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (video incl)
Old Sep 1, 2004 | 04:37 PM
IVI's Avatar
IVI
Default IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (video incl)
well.
im having trouble with my code 14, and my idle ONLY at 1,500 rpm's.
the iacv i used is the 2nd iacv i tried. wires are good. connector is good. continuity is good. i even ran a wire from a9 to the iacv itself. nothing helps.
i pull the connecter out, no change in idle.
car starts up fine. drives fine. sounds like it hits a rev limiter at 1,500 at 5% throttle. any more throttle and it works fine.
motor is a jdm b16 - stock p28 ecu - gsr 1996 obd2 wiring harness with obd1 jumper harness.
here is a video of the problem im having too.
right click - save as :
http://www.we-todd-did-racing....DE%3D
this all has been done already :
Old Sep 1, 2004 | 06:18 PM
len's Avatar
len
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (IVI)
Slight chance you may have your ECT sensor plugged in incorrectly?
Experienced the same symptoms in my 97 ITR. Because my CFK sensor plug was hacked off, I was forced to purchase a new engine wire harness.
After I replaced that, my problem went away.
Old Sep 1, 2004 | 06:45 PM
IVI's Avatar
IVI
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (len)
water temprature sensor ?
i disconnected this earlier today to repair the water heater hose right under the distributor. i forgot to plug it in and flashed a code 6, so im pretty sure its plugged in right.
thanks for the reply btw. any other ideas or suggestions?
Old Sep 2, 2004 | 05:10 AM
SlapSmak's Avatar
Reading through this you say "stock P28 ECU"
what map is the P28 running? is it out of a SOHC civic or from a b16 laden delsol?
Old Sep 2, 2004 | 05:30 AM
IVI's Avatar
IVI
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (SlapSmak)
its for a sohc
Old Sep 2, 2004 | 10:22 AM
Doctor CorteZ's Avatar
milled head ?
stock compression ?
what motor ?
Old Sep 2, 2004 | 10:25 AM
IVI's Avatar
IVI
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (Doctor CorteZ)
everything stock
jdm b16
Old Sep 2, 2004 | 10:37 AM
fast idle thermo switch ?
Old Sep 2, 2004 | 03:09 PM
IVI's Avatar
IVI
checked it and screwed it already not even 3/4 of a turn.
Old Sep 2, 2004 | 06:32 PM
SlapSmak's Avatar
well, your main issue could be maps for a SOHC motor when running the B16. I have had a fast idle issue also with my P28, but it is chipped and running a tuned map. Once hot it runs fine and idles a little high, but I think I have the solution for that, gonna try it tomorrow to see. Why dont you chip your ECU and put a B16 base map on it?
Old Sep 2, 2004 | 07:18 PM
IVI's Avatar
IVI
im going to try someones chipped ecu tonight to see what happens.
i dont relaly have the time to order anything because im probably leaving this saturday out of state with the car - moving.
Old Sep 2, 2004 | 11:53 PM
IVI's Avatar
IVI
chipped p28 did not let my car start for some reason.
going on a very long road trip saturday would like to get it fixed before hand.
suggestions please!
Old Sep 3, 2004 | 12:09 AM
Art Vandeleigh's Avatar
could it be EGR? have you looked at the fast idle?
Old Sep 3, 2004 | 12:21 PM
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (Art Vandeleigh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art Vandeleigh &raquo;</TD></TR><TR><TD CLASS="quote">could it be EGR? </TD></TR></TABLE>
doesnt exist.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Art Vandeleigh &raquo;</TD></TR><TR><TD CLASS="quote">have you looked at the fast idle? </TD></TR></TABLE>
he stated he already checked that.
Old Sep 3, 2004 | 12:29 PM
Its_real&its_spectacular's Avatar
New User
I'm just trying to clarify the problem. It idles at 1500rpms? Unplug the IACV and set base idle (the screw on the throttle body)
Or is it that there's a dead spot off idle at 1500rpms? If that's the case then its got nothing to do with the IACV at all, its more likely a nonlinear spot on the TPS or something like that.
Oop, just watched the video, sorry. That's really odd. It limits @1500rpm until the computer goes into limp mode, then allows it to rev up. Still, above 1500 the IACV has nothing to do with it. The computer is sending you barking up the wrong tree there. I can't remember if any of the connectors are the same as the IACV plug... Any chance something is plugged into the wrong place?
Modified by Its_real&its_spectacular at 2:40 PM 9/3/2004
Old Sep 4, 2004 | 07:13 AM
IVI's Avatar
IVI
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (Its_real&its_spec
im not sure what it is.
the only code im getting is the iacv.
the iat has the same plug as the iacv but i already made sure everything is in the proper place.
Old Sep 5, 2004 | 12:41 AM
- Sim -'s Avatar
hmm i ve nearly same prob. idle @1500 rpm new iacv installed....
can you please upload the vid again, so that i can download it also.
would be good.
thanks
Old Sep 5, 2004 | 07:19 AM
xcivic_ex
Guest
Posts: n/a
friends car does the same exact thing.. quite possibly a bad iacv.. or wiring.. run wires from A9+ i think and A23-.. or it might be reversed. if you get no change with wires straight from the ECU to the sensor then most likely the IACV.. if it does change then your wiring is messed up somewhere.
95civicB16
Sep 22, 2007 12:21 PM
IVI
45
Oct 30, 2004 03:31 PM
allmotorsi04
May 11, 2004 04:49 PM
