horrible vaccum leak......
Old Sep 1, 2004 | 03:54 PM
b18Gooch's Avatar
Default horrible vaccum leak......
A buddy of mine is having a major problem with a vaccum leak. We have checked all vaccum sources that we can think of and we have not found anything. Any suggestions as to where else we can look. We checked all vaccum lines, the Charcoal cannaster that sits next to the battery on the firewall, the IM, He is currently running a turbo setup and we checked all vaccum lines. Has anyone had any problems with the charcoal cannaster before or can someone offer up some suggestions as to where whe could look!
Thanks in advance!
Kevin
Old Sep 1, 2004 | 04:35 PM
Mr T's Avatar
Default Re: horrible vaccum leak...... (b18Jay)
what makes you think the car has a vaccum leak ??? what does the car do ?
Old Sep 1, 2004 | 06:00 PM
b18Gooch's Avatar
Default Re: horrible vaccum leak...... (Mr T)
The car is idiling up and down, but the problem is..... It does it off and on. It does not do it at all times, but when it does do it, it is up down up down up down, and quite noticable. thats what leads me to believe that its a vaccum leak.
Old Sep 2, 2004 | 02:25 AM
eg6T's Avatar
idle air contol valve,or idle air thermal valve..
Old Sep 2, 2004 | 03:57 AM
Mr T's Avatar
Default Re: horrible vaccum leak...... (eg6T)
It may also be a low coolant level that would cause that . have you checked the coolant ?
Old Sep 2, 2004 | 06:59 AM
b18Gooch's Avatar
Thanks for the quick replys. It was weird, all of a sudden, he started to throw a CEL and we checked it and it was the IAC valve. he put a new one on and it seems to be idiling much better! Coolant was a little low also. So all info was helpful!
Thanks for the help!
Kevin
Old Sep 2, 2004 | 07:03 AM
FOrSfEd's Avatar
I had the same problem, check everything that has been mentioned and I never found the problem. But when I sold my last turbo kit and out it back to factory all of a sudden I didn't have a vac leak anymore. Not sure where it was coming from but it was def a leak that had something to do with my turbo
Old Sep 2, 2004 | 09:38 AM
b18Gooch's Avatar
Default Re: horrible vaccum leak...... (FOrSfEd)
Its weird, because he has been boosted for a while, but recently upgraded from a Drag 3 turbo to the Sc-61 and he all of a sudden has a vaccum leak. We are gonna check it again today to see what we come up with. Thanks again for all the quick responses!
Kevin
Old Sep 3, 2004 | 04:06 AM
eg6T's Avatar
so what your tryin to say was..i was right?thank you,thank you
Old Sep 14, 2004 | 06:06 PM
kihun_cha's Avatar
shti im in idle problem help me out brothers
Old Sep 14, 2004 | 06:59 PM
FOrSfEd's Avatar
Default Re: (kihun_cha)
Another thing it might be and you might want to try this, but the vac line that is coming off the turbo, run another line from there and block it off with a screw and tell me if that fixes the problem. I know it sounds kinda stupid but try it and see if it works
Old Sep 14, 2004 | 07:38 PM
kihun_cha's Avatar
oops sorry.. my car is N/A my badddd
but still tell me the solution
Old Sep 15, 2004 | 10:32 AM
FOrSfEd's Avatar
up, cause I want to see if that worked
Old Sep 15, 2004 | 10:39 AM
kihun_cha's Avatar
i bought a carb cleaner and cleaned throttle but seems to be the same ****..
im gonna reset ecu..
but how do u do it?
just take out battery for more than 15minutes?
honcrf150
13
May 29, 2012 10:28 AM
lurkin' eg
Jul 18, 2008 10:15 PM
Silent_Destruct
May 24, 2006 02:10 PM
galioth
Oct 28, 2004 03:47 PM
team2n1hatch
10
Apr 2, 2003 03:32 PM
