IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (video incl)
Old Sep 1, 2004 | 03:13 PM
IVI's Avatar
IVI
Default IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (video incl)
well.
im having trouble with my code 14, and my idle ONLY at 1,500 rpm's.
the iacv i used is the 2nd iacv i tried. wires are good. connector is good. continuity is good. i even ran a wire from a9 to the iacv itself. nothing helps.
i pull the connecter out, no change in idle.
car starts up fine. drives fine. sounds like it hits a rev limiter at 1,500 at 5% throttle. any more throttle and it works fine.
motor is a jdm b16 - stock p28 ecu - gsr 1996 obd2 wiring harness with obd1 jumper harness.
here is a video of the problem im having too.
right click - save as :
http://www.we-todd-did-racing....DE%3D
this all has been done already :
Old Sep 1, 2004 | 04:57 PM
IVI's Avatar
IVI
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (IVI)
bumping
someone has to have some kind of suggestion!
Old Sep 1, 2004 | 05:36 PM
B_CRUZ!'s Avatar
switch the map and tps plugs. check for leaks in the manifold by spraying it with carb cleaner while the engine is running. if the idle stutters while you are spraying, thats where the leak is.
also check the tension of the throttle cable.
Old Sep 1, 2004 | 05:41 PM
iH8RICERZ's Avatar
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (b cruz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b cruz &raquo;</TD></TR><TR><TD CLASS="quote">switch the map and tps plugs. check for leaks in the manifold by spraying it with carb cleaner while the engine is running. if the idle stutters while you are spraying, thats where the leak is.
also check the tension of the throttle cable.</TD></TR></TABLE>
just was about to say something similar to that....
also, why are you running a stock p28 on a b-series?
Old Sep 1, 2004 | 05:43 PM
IVI's Avatar
IVI
i checked the plugs straight to the computer, everything is hooked up right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">
also, why are you running a stock p28 on a b-series?</TD></TR></TABLE>
the ecu i had burnt out, it was a chipped p28. the stock p28 is all i have right now.
everything works except this. it makes the car jerk too. im about to take a long distnace trip in a couple of days and id like to have it fixed before i go.
Old Sep 1, 2004 | 05:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
well I would think that the air/fuel maps in a stock P28 (D16Z6 SOHC VTEC if OBD1) would be quite incorrect for a B16 DOHC VTEC. That's the only thing I can think of off the top of my head.
Old Sep 1, 2004 | 05:57 PM
IVI's Avatar
IVI
Default Re: IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (PatrickGSR94)
so you think i should change the ecu or chip it ?
Old Sep 1, 2004 | 09:04 PM
IVI's Avatar
IVI
bumping
any suggestions, ideas, comments, questions?
Old Sep 2, 2004 | 12:51 AM
SivikHatch's Avatar
You could get it socketed by TooLowSol for 75 bucks.
Old Sep 2, 2004 | 01:44 AM
JBBNJ609's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">well I would think that the air/fuel maps in a stock P28 (D16Z6 SOHC VTEC if OBD1) would be quite incorrect for a B16 DOHC VTEC. That's the only thing I can think of off the top of my head.</TD></TR></TABLE>
Old Sep 2, 2004 | 05:53 AM
IVI's Avatar
IVI
will let you guys know tonight.
Old Sep 2, 2004 | 08:53 AM
yojasonyo's Avatar
try the eacv the valve under the tb i beleive, thats what my car was doing and it wasnt the iacv
Old Sep 2, 2004 | 09:03 AM
IVI's Avatar
IVI
Default Re: (yojasonyo)
i already checked the fitv.
Old Sep 2, 2004 | 09:20 AM
B_CRUZ!'s Avatar
Default Re: (IVI)
also maybe your tach is off. I know I was having the same issues 2 years ago and it turns out the OE tach went bad.
Old Sep 2, 2004 | 03:09 PM
IVI's Avatar
IVI
Default Re: (b cruz)
why would the tach being off make the rpm's do that tho?
it seems to be on target to where vtec crossover is and the rev limiter. + - 100 rpm
Old Sep 2, 2004 | 11:53 PM
IVI's Avatar
IVI
tried a friends p28 chipped ecu, did not let my car start.
any more suggestions?
going on a long road trip saturday would like it fixed before!
Old Sep 4, 2004 | 07:12 AM
IVI's Avatar
IVI
bumper
Old Sep 4, 2004 | 09:52 AM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">tried a friends p28 chipped ecu, did not let my car start.
then something is definitely wrong with your wiring on your part if you tried another ecu.
95civicB16
Sep 22, 2007 12:21 PM
IVI
45
Oct 30, 2004 03:31 PM
Skyllz
Sep 18, 2003 04:59 PM
