Someone help! Can't change the rear brake pads!
Old Sep 1, 2004 | 02:29 PM
bpetruzzo's Avatar
Default Someone help! Can't change the rear brake pads!
Ok, so here is what happend, a friend was changing the rear pads on my 93 Civic Si. We got the caliper off, and we removed the cap on the brake fluid. When we were using the clamp to compress the brake it wouldn't go in at all. And after a while, we tried pumping the brake, but didn't relize the clamp was off, and the brake shot out like an inch. Well, long story short, we cant get it to go in. It wont budge. Does anyone know why the brake wouldn't go back in!? My friend says the brake must be locked up somewhere else in the line.
Any thoughts?... someone please say you've got thoughts..
Old Sep 1, 2004 | 02:45 PM
Ricey McRicerton's Avatar
Default Re: Someone help! Can't change the rear brake pads! (bpetruzzo)
Your asking about the rears right? They have that X pattern on them for a reason. You screw them down instead of compressing them with a C clamp like the fronts.
dantastic's Avatar
you can't use a clamp to push the piston inwards. you need to use a pair of needle nose pliers or something similar to screw it back in. i'm pretty sure u have to turn the piston clockwise to get it to go in.
Old Sep 1, 2004 | 02:55 PM
bpetruzzo's Avatar
Default Re: Someone help! Can't change the rear brake pads! (dantastic)
Awesome! Thanks so much guys! I'll give that a shot!
leviq
Jul 7, 2007 08:28 AM
Ms.JDMdb8
Jul 8, 2005 03:53 PM
bboylito
Sep 21, 2004 11:05 PM
DaKINE-Ek
May 22, 2004 02:40 PM
AK94GSR
May 30, 2003 01:31 PM
