Y8 oil pan on a Z6
Old Sep 1, 2004 | 02:06 PM
funkfnamna's Avatar
Default Y8 oil pan on a Z6
i'm puting back together my turbo rex but i had to change the block over to a Z6 from the Y8 I was using. anyone know if the Y8 pickup and pan will work??
Old Sep 1, 2004 | 02:52 PM
SprayinCX's Avatar
Default Re: Y8 oil pan on a Z6 (funkfnamna)
don't hold me to this but someone told me that the oil pan was different on the y8 engines. something about the y8 ones was cast and teh others are something? anyway they also said something about the deepth of the oil pans.
sorry for the bad... well everything. i wasn't paying them any attention.
Old Sep 1, 2004 | 03:07 PM
Dengar's Avatar
Default Re: Y8 oil pan on a Z6 (SprayinCX)
No they will not fit. When I was installing my turbo I had a tapped y8 pan and it did not line up correctly on my z6.
Old Sep 1, 2004 | 03:53 PM
1niceSi's Avatar
Default Re: Y8 oil pan on a Z6 (Dengar)
Nope it won't fit....Z6 pans and Y8 pans are NOT interchangeable.
Old Sep 2, 2004 | 07:48 AM
funkfnamna's Avatar
Default Re: Y8 oil pan on a Z6 (1niceSi)
so what pans will fit on a Z6??
Old Sep 2, 2004 | 08:22 AM
Average Al's Avatar
a6
Old Sep 2, 2004 | 08:24 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1niceSi &raquo;</TD></TR><TR><TD CLASS="quote">Nope it won't fit....Z6 pans and Y8 pans are NOT interchangeable.
Interesting you say that, since I"m running a tapped Z6 pan on my Y8-T.
Two of the bolts on the crank pulley side need to be drilled out slightly, but other than that it's a straight bolt up.
Old Sep 2, 2004 | 11:46 AM
funkfnamna's Avatar
Default Re: Y8 oil pan on a Z6 (boostincoupe)
i was just coming on to say that. i lined up the pan andthe 2 studs on the oil pump don't line up. hrm i have a y8 oil pump here......... i'll just have to plug up the dip stick hole!
cvcrcr99
Feb 14, 2010 07:12 PM
JDM96SpecCTR
Feb 4, 2005 02:31 PM
gloryhog
May 14, 2004 04:33 PM
tinkfist
Oct 16, 2002 04:28 PM
