Just bigger injectors a performance mod?
I started gathering my parts for my turbo setup. I got some rc engineering 550cc injectors.
I rememeber I read in honda high performance handbook that bigger injectors are a good way to increase hp on an otherwise stock application.
well i cant find my book to make sure. Are they going to help me on a stock b18b1?
thanks a lot
thanks a lot
I dont see how.. If your getting the correct air/fuel ratio with the stock injectors then that shouldnt change when going to bigger ones.. Also remember, you need to find a way to pulse the bigger injectors slower..
You CANT just put them into your stock car with a stock ecu and have them work correctly..
Modified by tgreaves at 3:44 PM 9/1/2004
you have to find the happy medium between fuel pressure and fuel flow.
with a stock ecu and injectors that big, you wont even be able to start the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">Bigger injectors CAN increase horsepower on a stock application SOMETIMES. But 550s are just too big. </TD></TR></TABLE>
Only way I can see this happening is through efficiency..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">
Only way I can see this happening is through efficiency..</TD></TR></TABLE>
That is correct
That is correct
That is correct</TD></TR></TABLE>
Ahhh..
Ahhh..
