Moisture in corner light housings.
I have this problem with my one corner light housings, somehow or another the seal broke. Can anyone think of a way to fix this, or should I just replace it.
I was thinking about replacing it with some cheap eBay clear corners.
Got the same problem myself. I'm thinking of taking the bulb out, letting it dry out or speeding it up with a hair dryer, then sealing it as you said. I also know ppl who's lights have vented themselves a week later to so play it by ear.
i had a mustang that done that and i took out the park lamp assembly and drilled a small hole in the bottom like a 1/4 inch hole then once it dried out never had the problem again hope this helps
I have this recurring problem on some factory headlights I cleared out. They get just a bit of condensation in them after it rains. Haven't felt like dealing with out so I take out the corner bulb for about 10 minutes and it dries completely out. I would suggest doing that and then putting some good silicone around it.
Short Answer: Do what they said.
wireprobs
Jun 5, 2014 07:18 AM
CR-XSI91
Sep 23, 2012 09:56 PM
trooper0641
Mar 2, 2005 04:36 PM
