Corner light trouble
Old Dec 2, 2003 | 03:20 PM
FlaN.'s Avatar
Default Corner light trouble
okay, I changed out my OEM yellow/clear corner lights for some new all yellow corners on my teg. the large bulb on both sides blinks, and shines great. the smaller bulb doesn't. after I installed the lights the smaller bulb didn't even come on, and this is on both sides. I'm wondering if by me removing the bulb, the bulb was broken or maybe the dirt within the plug was shifted to cause the light to not work anymore. here's some pics:
see one light working.
it's dirty in there....
white buildup?
TIA
Old Dec 2, 2003 | 03:28 PM
BolivianDc2's Avatar
Default Re: Corner light trouble (theJUMPoff)
looks nice like that, keep it
Old Dec 2, 2003 | 03:33 PM
SIanara's Avatar
scrape off the build up and try it then... it might have a bad connection from all that gunk. i just did that with mine and it worked perfect after that..,..
Old Dec 2, 2003 | 03:35 PM
FlaN.'s Avatar
Default Re: (vteGraGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteGraGSR &raquo;</TD></TR><TR><TD CLASS="quote">scrape off the build up and try it then... it might have a bad connection from all that gunk. i just did that with mine and it worked perfect after that..,..</TD></TR></TABLE>
yea, i tried gettin some of it off with a stick while I was outside.. lemme give it another shot.
Old Dec 2, 2003 | 04:01 PM
FlaN.'s Avatar
can't find good enough materials to get that crap off. what did you use to scrape it off? I got most of it out, but they're still not working!!
Old Dec 2, 2003 | 04:36 PM
SIanara's Avatar
Default Re: (theJUMPoff)
i just used a screwdriver to get rid of that corrosion....just scraped it off... u want the surface to look like brand new metal.
Old Dec 2, 2003 | 04:41 PM
Catera's Avatar
yo i had the same problem so i bought new little bulbs in clear for likr 1.99. i tested my lights before i changed them and they worked fine. put in the new lights turn them on to see how it looks, and they dont work! i was like what happened so i just changed em.
xprometheusx
Aug 22, 2014 10:39 AM
invader_zim
Mar 28, 2012 09:57 PM
shortlid
Nov 29, 2007 01:53 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
darylfiend11
Mar 10, 2004 06:25 PM
