Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Koni with Ground Control Question...
Old Sep 1, 2004 | 10:40 AM
Naturally Aspirated's Avatar
Default Koni with Ground Control Question...
I drive a 99-00 Civic. I own a set of koni yellows, and a set of ground control coil overs.. These coil overs are making some noises that i dislike alot..
I read the GC website about a set that can convert the shocks and coilver into a full coilover system, would it solve my noice problem?
here's the first description (KONI KIT):
"Specially made for Koni shocks, This is a kit that mounts DIRECTLY to the snap ring on the Koni shock. Very popular with Autocrossers. very slick. We also rebuild and revalve Koni shocks in our shock department."
Here's the second one (K.O.W. KIT):
This is a very special kit for certain Koni shocks. Converts a Koni Sport to be a complete coil-over. If you want a complete threaded body shock, the most important thing is: Who made the guts for that shock? Koni makes an excellent shock.
Here's the address if u wanna llok at the pics:
http://www.ground-control.com/...b7e9f
Thank You before hand!
Old Sep 1, 2004 | 10:59 AM
.RJ's Avatar
.RJ
Default Re: Koni with Ground Control Question... (Naturally Aspirated)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naturally Aspirated &raquo;</TD></TR><TR><TD CLASS="quote">would it solve my noice problem?</TD></TR></TABLE>
Depends on what the noise problem is.
If the springs are too short so when you go over bumps the springs rattle on the perches.
Old Sep 1, 2004 | 11:07 AM
TeamSlowdotOrg's Avatar
I drive a 00 Civic and have had no noise or noice problems with them. If you aren't using GC's Koni adapters, you should be.
Default Re: Koni with Ground Control Question... (.RJ)
it's like when ever my wheels are rolling on the ground, i hear rattling sound from rear constatnly, and once the car stops, the sound will be gone, and i am sure that it's either the suspension, or the vinyl above the trunk and the glass was rattling together.
Old Sep 1, 2004 | 11:09 AM
.RJ's Avatar
.RJ
Sounds like you dont have the right sleeves.
Old Sep 1, 2004 | 11:10 AM
Soooo tighten everything on the suspension and if that doesn't fix it, sell your car.
Default Re: Koni with Ground Control Question... (TeamSlowdotOrg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamSlowdotOrg &raquo;</TD></TR><TR><TD CLASS="quote">If you aren't using GC's Koni adapters, you should be. </TD></TR></TABLE>
can u please gimme more info on that GC's Koni adapters?
Old Sep 1, 2004 | 11:11 AM
No, but GC can. Call them, they're open right now.
Old Sep 1, 2004 | 11:12 AM
what are sleeves?
is that the black plastic cylindershaped thing that wraps around the shock?
Old Sep 1, 2004 | 11:27 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naturally Aspirated &raquo;</TD></TR><TR><TD CLASS="quote">is that the black plastic cylindershaped thing that wraps around the shock?</TD></TR></TABLE>
I'm assuming these were installed properly.
But the black plastic spacer should be a very tight fit on the shock. The threaded sleeve should be a very tight fit on the spacer. If they're not, they will rattle and probably fail.
apexinghonda's Avatar
If you have GC sleeves it is a red anodized threaded cylindrical sleeve on the body of the shock and it will have a gold collar or ring the runs up and down on the threads to adjust height. If you don't have that then you don't have GC sleeves.
Barry H.
Old Sep 1, 2004 | 11:30 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamSlowdotOrg &raquo;</TD></TR><TR><TD CLASS="quote">Soooo tighten everything on the suspension and if that doesn't fix it, sell your car.
I have a realy short spring, it's the eibach springs that came with the GC. I dropped my car pretty low, so when the car is jacked up, the spring is not compressed to the top cover, it's kinda like free moving... so when i unjack my car, springs might not be inside the top cover, that's what i am thinking that caused the rattling noise...
i asked if i should change the spring to longer length, but alot of tech members said that longer springs are not as good...
Old Sep 1, 2004 | 11:32 AM
i think that's it, that's the F'ing problem, the shop who put it on said that thos plastic tubes doesnt do ****, so they left it out... Thank YOu sooo much, i willl put thos back on...
Old Sep 1, 2004 | 11:35 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naturally Aspirated &raquo;</TD></TR><TR><TD CLASS="quote">so when the car is jacked up, the spring is not compressed to the top cover, it's kinda like free moving... so when i unjack my car, springs might not be inside the top cover, that's what i am thinking that caused the rattling noise...
i asked if i should change the spring to longer length, but alot of tech members said that longer springs are not as good...</TD></TR></TABLE>
When you go over bumps the spring is unloading and rattling. Nothing at all wrong with longer springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naturally Aspirated &raquo;</TD></TR><TR><TD CLASS="quote">i think that's it, that's the F'ing problem, the shop who put it on said that thos plastic tubes doesnt do ****, so they left it out... Thank YOu sooo much, i willl put thos back on...</TD></TR></TABLE>
Who installed them so we can say away?
Old Sep 1, 2004 | 12:07 PM
PANN AUTO IN SAN DIEGO, I stopped goin there since last year, i guess i found out that they do bad jobs tooo LATE!!
Old Sep 1, 2004 | 08:44 PM
slammed_93_hatch's Avatar
the new GC 'baby tubes' are the ****
kevinm1981
Suspension & Brakes
10
Jul 12, 2009 01:13 PM
tegrunner
Suspension & Brakes
Jun 11, 2005 08:54 AM
DOHCTOR
Dec 26, 2002 09:14 PM
96 SOHC VTEC
24
Jan 27, 2002 07:56 PM
eracer325
Dec 27, 2001 01:36 PM
