Benson Sleeved/ Import Builders pistons/ Toda C charts
Old Aug 31, 2004 | 10:24 PM
b19coupe's Avatar
Default Benson Sleeved/ Import Builders pistons/ Toda C charts
Went to one of my favorite places in the world: Church Automotive Testing.
Shawn worked his magic and managed to pull some decent gains out of the old ITR. Blew up the motor a few months back so Dan Benson sleeved it for me and Jeff from Import Builders hooked me up with some 81.5mm Wiseco pistons. The engine is running Toda 'C's and Hondata.
Here is the before and after (tuning) torque graph:
Before and after (tuning) HP:
Here is a graph of the old motor (stock block, Skunk2 Stage 2 cams) vs the new (love that Toda mid-range ):
Finally, we slapped on Shawn's magic dyno intake to see if there were any gains to be had (over the AEM CAI). As you can see, they were pretty close-the intake resonance was just at different rpm points:
I would like to thank Shawn for an awesome job tuning the motor, Jeff for getting me those pistons (IB Spec Wiseco pistons always deliver ), and Dan Benson for another flawless block
Old Aug 31, 2004 | 10:32 PM
ArinX's Avatar
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (b19coupe)
what compression you at
nice numbers
Old Aug 31, 2004 | 10:45 PM
HoOridin's Avatar
nice numbers for an 1.8.....
Old Sep 1, 2004 | 12:22 AM
Pondus's Avatar
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (ArinX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX &raquo;</TD></TR><TR><TD CLASS="quote">what compression you at
nice numbers </TD></TR></TABLE>
I 2nd this, was the cr the same4 as your old setup with S2S2 cams or did you bump it up on the rebuild?
Old Sep 1, 2004 | 12:34 AM
itralex's Avatar
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (Pondus)
niice, this sorta looks like my setup
what header are u running and what CR?
Old Sep 1, 2004 | 12:42 AM
EMO-anthony's Avatar
Nice numbers!
Old Sep 1, 2004 | 03:22 AM
RobbieG35's Avatar
12 Years Strong
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (THAiGuYDc2)
I think a video through the gears is in order
Old Sep 1, 2004 | 04:47 AM
Charlie Moua's Avatar
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (HybridHatch88)
what compression ratio?
Also how many miles did you break in the new motor & rings on?
Old Sep 1, 2004 | 06:03 AM
b19coupe's Avatar
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (Charlie Moua)
Compression is around 11.5-12:1. 400 miles on the motor since the rebuild. Header is the Comptech 4-2-1 race header. Hytech header coming soon
Old Sep 1, 2004 | 06:31 AM
Rick Solis's Avatar
Im thinking the Toda C's are a little too much cam for that motor... Id say try and get your hands on a set of JUN 3's and see which of the 2 the motor likes better...
Damn nice #'s for a 1.8 grocery getter...
Old Sep 1, 2004 | 01:08 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (Rick Solis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rick Solis &raquo;</TD></TR><TR><TD CLASS="quote">Im thinking the Toda C's are a little too much cam for that motor... Id say try and get your hands on a set of JUN 3's and see which of the 2 the motor likes better...
Damn nice #'s for a 1.8 grocery getter... </TD></TR></TABLE>
You need at least high 12s compression to get the full potential out of Cs anyway don't you?
Old Sep 1, 2004 | 03:23 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 &raquo;</TD></TR><TR><TD CLASS="quote">
You need at least high 12s compression to get the full potential out of Cs anyway don't you?</TD></TR></TABLE>
Yes, 12,5:1 or so would be nice on Toda C cams.
Old Sep 1, 2004 | 05:37 PM
velocitytrends's Avatar
Default Re: Benson Sleeved/ Import Builders pistons/ Toda C charts (Manuel)
Nice Build, Nice Graph, JEFF IB !
Old Sep 1, 2004 | 08:04 PM
mtber's Avatar
Nice :-)
Old Sep 1, 2004 | 09:01 PM
machonda's Avatar
great job! sounds like you a fast street car for 91 octane!
Old Sep 1, 2004 | 10:28 PM
skunk2powered's Avatar
very nice numbers!
Old Sep 1, 2004 | 11:46 PM
OLM-02R's Avatar
nice #
Old Sep 2, 2004 | 09:21 AM
TECH43 RACING INC.'s Avatar
Default Re: (OLM-02R)
so thats about 194 whp on a dynojet, correct? shawn was telling me last week that its about 20 hp higher.
Old Sep 2, 2004 | 10:59 AM
b19coupe's Avatar
Default Re: (TECH43 RACING INC.)
More like 202 on a DynoJet. The old motor made 202 on Shawn's dyno and 192 at Rage Performance. I will probably hit a DynoJet for a baseline in the coming months just to compare.
Old Sep 2, 2004 | 11:20 AM
vtec69's Avatar
very nice for a 81.5mm
Old Sep 2, 2004 | 04:26 PM
Carlo Gambino's Avatar
Todd ... where is your JECKYL N HYDE engine?? whats the latest news on it ???
Old Sep 2, 2004 | 04:35 PM
b19coupe's Avatar
Default Re: (Carlo Gambino)
Block is together. If all goes well the car should be running this weekend. The only problem is that Hurricane Howard is generating some awesome swell, so I might be surfing when I should be putting the engine in
Old Sep 3, 2004 | 02:42 PM
wow todd.... you man are rich !!
you build this, and then you build that ...
keep the good work todd ,keep us update
b19coupe
May 18, 2004 07:23 AM
95gsr
Jan 26, 2004 04:14 PM
GQ 05YellowEVO8
Jan 16, 2003 02:08 AM
sgT
Mar 25, 2002 01:20 PM
ITR111
Oct 9, 2001 09:43 AM
