oil leaking on downpipe! oil pan gasket help needed
Old Aug 31, 2004 | 08:51 PM
LAKER HATER's Avatar
Default oil leaking on downpipe! oil pan gasket help needed
i need to replace my oil pan gasket again. oil is leaking out of one of the edges and slowly pouring down the downpipe causing it to burn black. my downpipe is ugly looking now.
i dont have a torque wrench and i know people who just hand tighten it. i've asked techs at honda and acura dealers and they say they hand tighten it with a wrench as well.
what exactly is "hand tight"? do i tighten it until i cant tighten it with my hand anymore? if i apply enough force it will turn slowly, but how do i know when to stop? so i just turn it to the point where it wont turn anymore? do i turn it to the point where its tight but could be tighter if i lean more into the turn? i dont want to keep buying oil pan gaskets. it gets costly.
please help!
Old Sep 1, 2004 | 02:15 AM
eg6T's Avatar
Default Re: oil leaking on downpipe! oil pan gasket help needed (LAKER HATER)
when you put the oil pan gasket on,use some gasket sealer...when you tighten the bolts down,they do not have to be very tight,make sure you are not tightening so much so that u compress the gasket.cant really explain hand tight,just tighten it till u the the gasket compress just a little
Old Sep 1, 2004 | 07:33 AM
Tchleung's Avatar
it's 10 foot pounds for each nut.bolt
Old Sep 9, 2004 | 06:00 PM
Turbocoupe97's Avatar
Default Re: (Tchleung)
its 7.3 lbs of torque
Old Sep 9, 2004 | 06:53 PM
Tchleung's Avatar
Default Re: (Turbocoupe97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocoupe97 &raquo;</TD></TR><TR><TD CLASS="quote">its 7.3 lbs of torque</TD></TR></TABLE>
Oops jsut rechecked. it's 9 ft pounds. Don't know where you are getting 7.3 from. But it's 9 for his B18 LS from the Helms
Old Sep 9, 2004 | 07:07 PM
wantboost's Avatar
Who is Mr Robot?
use some honda-bond on the low places, works like a charm
phelpsj2
Mar 9, 2010 12:16 PM
deconstruct
Jun 18, 2004 01:00 PM
IntegraB18A
Dec 20, 2003 08:18 PM
r7
Apr 19, 2003 12:29 PM
yellowbulbs
Jul 17, 2001 01:12 PM
